Easy Slider z32 missile
  • Really enjoy the fab work going on here, but this I don't get:
    You made it so that the pipe can no longer be removed without unbolting 2 bolts that are behind a cam-gear? Doesn't seem to help for any maintenance...
    • Originally posted by TeckniX View Post
      The mounts are slotted (sorry no pics forgot to add them) regardless they are not blocked by the cam gear at all there are 5 huge holes in the cam gear making it very accessible, takes all of maybe 2 min to loosen the two bolts and it lifts right out, trust me I have the ease of removal in the back of my mind at all times.
      • This would not be a turbo build without a blow off valve.
        I will be mounting this at an angle, so I need to use a 45 degree bend that will create a smooth transition.
        Fish mouthing the bend for a proper fit onto the charge tubing.
        Water tight!
        90 degree.
        Welding the BOV flange onto the 45.
        A little dye and scribe to mark out the hole.
        Yep that's a hole.
        Test fit.
        Now I know there is a raging argument of where you should put your BOV and both arguments seem valid that is why I decided to add another one.
        • Making something a little old school today. (video content)
          I bought this universal throttle cable kit, but I just did not like how the cable looked and there was just no real good way to run it the way I wanted.
          I am going to basically make an old school looking carburetor throttle linkage.
          This is going to be the outer race that the bearing will press into.
          Rough idea of where it will be mounted on the plenum.
          Thread to be pressed into bearing inner race.
          Here is the middle link cut out and finished along with the hiem that will be used.
          I will be giving the hiem's an inside thread for proper function and to aid in ease of removal, less parts ect...
          5 in total
          Snug press and there ya go.
          This is the throttle body butterfly link.
          Fasteners and all three links finished with the the adjustable hiem's.
          Since I will be using the universal cable kit for the transition through the firewall I will be in need of a way to securely hold the cable.
          Aluminum lug that will be the main structure to keep the cable in place.
          Had some brass bar lying around and thought why not use this for the cable clamp.
          Looking real fancy for a clamp at least.
          Mounted to the rear of the plenum.
          The sleeve to spread out the clamp force on the cable.
          Slides in real nice
          Simply hand tighten the bolt and you have a ridiculously solid holding mount. (side note, the rub marks on the plenum are from the fasteners that I had used before I made the threaded hiem inserts.)
          Rear link
          All together now
          Cool? and yes I could of just made the universal kit work but what would be the fun in that.
          Here is the link to the video.
          http://youtu.be/7i3cTfA8qyE
          • Strong pornography
            • This is Dopeeeee!
              Mx73 Cressida Build check it out!
              http://www.stanceworks.com/forums/sh...ad.php?t=59875
              Ig: Japetto516
              • Pornstastic!
                • More pleaseeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
                  • WHEELS
                    Thinking about a full polished look
                    On the fence to go color or to continue polishing
                    • white faces pls
                      but seriously white faces..
                      • this.
                        is.
                        AMAZING.
                        fab skills top notch.
                        beautiful car.
                        almost too pretty to drive.
                        nice job.
                        • damn
                          that car
                          those skilss
                          that work
                          Floccinaucinihilipilification
                          • The quality on this thread is soo damn high!
                            Big props to you on this build my man.
                            Instagram: @KingCavey
                            • ...this is insane.... who are you sir??!.... are your batman?
                              • Any update? Sorry to those excited because of thread bumped.
