this thing is so g. the wheels work so well I love it
my 89 190e
Well if you go air. You might not get enough rear lift. But they go low haha. Really ya just gotta play around with it. But the the coils bolt on. I had to make the top hole on the strut bigger to line up with the hub.Originally posted by TheGarageLife View PostDamn, definitely something to consider though if I'm going to go air. And as far as the front goes you just slapped on the Raceland coils for the E36? Did you have to make any major modifications? Besides the camber plates.
Instagram- Williammk1
Looks good man, what people were mentioning earlier about strength is that the strut towers of the 190e were not designed to handle the stress of having a spring and a strut pressure there. People who do the e36 coil conversion usually reinforce the strut tower.
Also, if you do a drive train swap I will buy that trans and flywheel setup off you. I've been looking for that flywheel for a long time. Feel free to pm me and let me know.
Good job with the car!Balls Deep Squad.
Correct, But you don't have to reinforce it. Yellow speed makes a set to do the full coil conversion. Only thing is there camber plates are a little thicker. If there using factory mounts then yea you would have to do something because they suck. Thats why i did the camber plates.Originally posted by w201e34 View PostLooks good man, what people were mentioning earlier about strength is that the strut towers of the 190e were not designed to handle the stress of having a spring and a strut pressure there. People who do the e36 coil conversion usually reinforce the strut tower.
But yea! ill most deff sell ya the whole factory 5 speed set up. I am not sure how much they go for. i guess offer me something and we can go from there
But thanks man!
[/QUOTE]
Hey I just noticed this, but where do I find an intake like this? I've been looking to change my housing out and using this piece and start making one out of aluminum.
And then also where do you get that hose to connect the PCV valve amd the crankcase to the breather since this intake is further away than the original?Last edited by TheGarageLife; 06-16-2014, 01:00 PM.
Hey I just noticed this, but where do I find an intake like this? I've been looking to change my housing out and using this piece and start making one out of aluminum.Originally posted by TheGarageLife View Post
And then also where do you get that hose to connect the PCV valve amd the crankcase to the breather since this intake is further away than the original?[/QUOTE]
Well i just had stuff laying around, the part on the intake, is from my Rabbit cis intake. the pipe is from ebay that i had on my old mk3 2.0l and the hose is a rad hose from my Rabbit. and the filter i had laying around, its a old one from my sisters TC haha.
Updates! I have traded the car to a friend for a 72 c10. But the build will continue..So don't worry
And ill post the c10 on a new thread soon. I also i traded my 83 Rabbit for 74 Cb350 bobber, Ill post some pictures of that soon. I don't get on here much anymore. Be free to follow me on Instagram username- Williammk1 I post most things on there.
