FC RX7 5.0 race car thread
  • #61
    Originally posted by Concon666 View Post
    I like this thread
    thanks dude.
    I'm really grateful the encouragement guys, kinda hit a wall with my patience level. but it should get better now that fab is mostly over.
    87 RX7 5.0 (driftcar)
    • #62
      Looks good! I just got back from a 200 mile round trip to pick up a Fox body T5 lol. Barely worth all that seat time, but oh well. It also sucks cause I still need a bellhousing and a shifter. Oh well, I didn't expect to start this project til next winter (which at this point I'm still just collecting parts without doing any real work). Also noticed on the trans I've got an open hole where something used to go, hopefully getting all the little bits I need for a complete trans don't cost me too much
      One more question, especially since you mentioned the trans mount. Does the kit require a Mustang trans bracket or does the Granny's kit just bolt straight to the T5? Sorry for asking all the questions I should just ask Granny's, hope you don't mind! It just seems there are some small gaps in the info they give you on their site and all the build threads you see online.
      • #63
        This is one of those threads that i wish was 20 pages long and i could see the finished product. Doing great so far. Fab work is amazing so far.
        • #64
          at this rate youll be done before me lol. Youre gonna be low right?
          Instagram: @B_OLSEN_
          1988 FC3s-LS3 track slut~in progress~
          1991 S13 Coupe-LS1 street beater
          2004 G35 Coupe track model-Work Wheels Static daily
          TUMBLR
          • #65
            Ya I feel like they're website is a bit lacking in the details in some areas. I tell you what I know and maybe that will help.
            So the kit comes in a few different variations, I recommend you buy as much as your willing to spend, as your probably going to have to fab the rest of what you don't buy.
            The basic kit comes with the crossmember cradle, and your choose of either a T5 or AOD (I think C4 is an option also) trans crossmember and matching tranny mount. The mounts are a custom piece as far as I understand, they aren't mustang or explorer mounts.
            All 302 blocks are the same (save for minor changes in the 70's to 90's) but this kit works with all ford small blocks that use a double sump oil pan (ala mustang)
            This kit will work LHD or RHD, power steering or not too. The cradle has holes in it designed to let you route the PS lines through it.
            I recommend getting the driveshaft made by them too, you'll need to know what trans your using and what diff (n/a or t2) is in your rx7.
            Kits also come with hardware for their pieces, everything uses as many factory placed bolts as able.
            The only thing that requires modifying is the shifter opening on the trans tunnel, you need to allow the shifter room forward of the current location. They also provide a T5 shifter leg adapter that moves the shift know back far enough that the dash opening doesn't need modifying.
            The stock rad also won't fit in the stock location, it will either need to be moved forward, or stood more vertical. They make a bolt in rad solution as well.
            I have yet to confirm with a SN95 front accessories, but the front sway bar will not clear either, you need to move it forward. Best way is to take the forward holes and make them the back holes, weld in new forward bolts.
            The sensor your missing is the speedo drive. Granny's website has a blurb on that too.
            Edit: wanted to clear a piece of misinformation here
            The kit doesn't come with mounts, but they are mounts for a 197x Mercury Comet (engine and trans). The rubber versions are super cheap, and I haven't found a company making sold or poly urethane mounts.
            Front accessories won't change the sway bar, it hits the oil pan. You'll need to move the bar forward.
            The Radiator will also need to be moved, or replaced. How much depends on which crank pulley you use. Electric fan is a must also.
            Dash will require modification as well as the tunnel to accommodate a T5
            my kit doesn't line up perfect to the bolt holes in my car, it took some wiggling. A friend bought the same kit for his t2 and his is even further away from the bolt holes then mine, so some hammering may be in order.
            Alternator will need to be a SN95 bracket or moved elsewhere. Fairly confident a fox or explorer bracket will cause it to hit (fox due to tensioner) but I haven't tried one other than the SN95 which fits with a hairs width to spare.
            Mods, don't go editing my thread without at least notifying me. And to Grannies or who ever felt the need to come in here, make a website that doesn't completely suck. The dash was clearanced in a later post. A fox alt relocation bracket will fit but makes for a really long belt. I think I even listed part numbers for the engine mounts. There is a company that made or makes (not sure if they still are) poly mounts but they were expensive. To anyone looking at buying a kit, regardless of the fact it's "jig welded" not a single one I've laid hands on has dropped in. They all take fighting and ruining of the powder coat to get it to sit correctly. The transmission crossmember also leaves very little room for an exhaust.
            -Teeson
            Thanx! Haha it'll get there
            • #66
              Oh it'll be low. Maybe not George Markovich low, but definitely hugging the ground.
              Haha you could easily beat me, just stop playing with that s13 for a while. Which btw did you rip the motor out of that?
              • #67
                Thank you very much for all the answers! I'm sure I'll ask some more as time goes on if you don't mind I actually am planning on going with the basic kit, mainly because I there's a driveshaft shop about 30 minutes away from my house that should have no problem with it (lucky me!) and I would rather not spend the money they want for a radiator.
                I can guarantee that after cursing myself and the parts I choose not to buy from Grannys I'll regret my decision. But that's usually how my car projects go I am extremely happy to have found this thread though, because by the time I start my car you will probably have a great example for me to follow
                EDIT: also kinda sucks about the front sway bar. At least there is a way to make it work. I would assume the stock SN95 accessories will clear everything alright based on the few builds (albeit foxbody engines) I've seen. I just started cutting down my factory cast SN95 accessory brackets last night. Too cheap to buy aftermarket brackets for running an alternator-only setup, so the sawzall is taking care of business!
                • #68
                  Ya I don't mind answering questions, thats what the internet and forums are for right?
                  The basic kit is totally worth the cost, the rad kit I feel is definitely overpriced. We'll have to see how I fare with the stock rad and a huge fan and lots of ducting.
                  The slave adapter kit they sell also doesn't appear to be useful, its basically all the parts you need with no bracket built, or adapter for the firewall (the hard parts) so no point in buying it through them
                  If you can handle fab work I've seen this swap done with out a kit, kit just makes it way easier.
                  The from sway may fit with SN95 stuff, I really hope it does. Been doing a lot of reading on suspension lately and if I move the sway bar forward it will alter the spring force it provides.
                  Are you putting the alt down low? I thought about putting it where the air pump was, but that makes the reverse rotation water pump impossible to use. The newer style timing chain covers (explorer, SN95) all use reverse rotation (relative to the crankshaft) water pumps.
                  This is how I was going to do until I get a good electric water pump:
                  you have a build thread somewhere I can follow?
                  • #69
                    So I have been working at it still,
                    been rocking out like I was back in high school
                    love these guys, were one of the first bands to combine rock/pop and modern electronic music properly. Their new album seems good so far, and before anyone says "mainstream" they made their sound popular, thats why its now "mainstream"
                    so back to last time, took the subframes all apart
                    IMG_5801
                    found the rear wheels bearings had play, soooo out they came
                    IMG_5817
                    Mating surfaces looked good
                    IMG_5814
                    but they was diiiiiirrty. So a quick one over with the wire wheel and they came out clean isn. I'm not gonna say I spent a ton of time on a part that no one will see and that's gonna get covered in brake dust and more importantly tire rubber
                    before
                    IMG_5813
                    after
                    IMG_5818
                    IMG_5820
                    ann denn
                    knocked the races off the hubs and painted them
                    IMG_5854
                    you know cuz everyone will see them under all the rotor and wheel and brake dust and tire rubber. lolz
                    these went nice and easy
                    IMG_5837
                    IMG_5838
                    can't say the same however for these stupid things
                    IMG_5846
                    I managed to get one of the trailing arm bushings out, but the other one however
                    IMG_5844
                    ruined my shop press!
                    So I'm getting a buddy to torch it out, no more of this risky sketchy pressing out business
                    so after that I got new bearings and seals. put the DTSS eliminators in too, they were pretty tough actually…
                    IMG_5840
                    ann denn
                    IMG_5841
                    annnnn dennn
                    IMG_5859
                    annnnnnnnnnn deeennnnnnn
                    IMG_5842
                    took the fronts apart and found no play! which is weird, cuz there was a bit of play in the front end, so that means ball joints.
                    and then just for the giggles (and maybe the internet fame) I did this
                    IMG_5810
                    and consider this the before pic
                    IMG_5803
                    they'll be an after when the subframe is reassembled.
                    and I'll leave you with this teaser
                    brake line goodies, hopefully doing these this weekend
                    • #70
                      Dammit. I need a garage and an fc shell now. Any wheel and aero plans?
                      • #71
                        yes and yes, but those are a secret for now I want to try some never done before stuff
                        • #72
                          Damn looking good, I am thinking about selling my FC with 5.0 swap. Or just the 5.0 swap lol. I'm ready to have boost again. Keep up the good work.
                          • #73
                            Looking good, great job, my friend at statusworks here in houston has one as well built 5.0 with a kb s/c.
                            • #74
                              This is super sick. Keep the updates rolling in. Inspiring me to get to work on my car!
                              INSTAWHAT
                              Tumblr
                              Flickr
                              • #75
                                haha theres a simple solution here
                                boost the 5.0
                                thanx! love to see pics/info! i'd imagine the kenne belle sticks through the hood, which would look pretty awesome. or you mean he has a 5.0 mustang with a KB?
                                thanx man! Stanceworks is what inspires me to get back in the garage, glad to contribute to the flame
