so im gonna be awesome and help you with your little ugly ass alternator/tensioner belt setup
I run a 302. With a clockwise rotating water pump (which yours is) from a late model fox body/early 90s crown vic.
SO. Ill make it super simple.
you need a March alternator bracket kit
This kit actually is designed to keep the alternator in the stock location. Well, if you bolt it up as said, then rotate the alternator 180degress, it underslings it. Then you route the adjuster between the crank and water pump and use a water pump stud that would normally hold the PS bracket in place, and mount it there.
This then uses the alternator to adjust pulley tension. ALSO get yourself the ribbed 90s crown vic pulley.
i would say just go get a crown vic water pump from auto store, and a pulley from a junkyard, its the old box crown vics.
All Imported-50 by Flsimages, on Flickr
All Imported-75 by Flsimages, on Flickr
All Imported-102 by Flsimages, on Flickr
[url=https://flic.kr/p/dcFHG9]
392536_3465183102901_1202704238_n by Flsimages, on Flickr
and done! for not much money you can make it beautiful and non ugly
Oh, and i used the miata slave also. Use a 3/4 bore master for perfect feel. Thats what i using
and yes. i actually read all 8 pages this morning
All Imported-102 by Flsimages, on Flickr[url=https://flic.kr/p/dcFHG9]
392536_3465183102901_1202704238_n by Flsimages, on Flickrand done! for not much money you can make it beautiful and non ugly
