You usually can't polish a chrome wheel. The process to properly remove the chrome coating is expensive and only done by a few shops.
E36 M3 Vert + Hardtop + Racing Dynamics
*update* January
Pulled the engine.... Did EVERY seal Possible, oh yea No more Slush box!
BTW if anyone knows how to flash a dme to manual please let me know
Fresh Magma Carpet to match door panels while tranny was out might as well
*Update* February
Decided I was tired of having mixed matched black body panels ( hood and door etc) So i got a local friend of mine to spray it E46 m3 JET BLACK.
New Front grill panel and New front bumper and support was must. Also a oem hood instead of the cheap china one previous own had put on.
(I noticed my vaders werent protected during this process..
2.17.14
Got the car back! Ran out of paint so the top didnt get sprayed
... will be dropping it off on the 24th to finished the job in time enough for cars and coffee
Also these bad boys show'd up
Scored this on ebay for 150$...
hopefully this will solve my CEL issue swapping the auto for a 5 speed. Does anyone know if i need to remove the auto computer all toggether if I used this flashed ECU?
I found a company here in houston that swears up and down they can blast the chrome off for 50$ a wheel... really considering this... Im at the point where i might a well just refinshed them myself once they're bear metal.Originally posted by Miroteknik View PostWhat I meant by polish, is to strip the paint off of them with chemicals, then use fine sandpaper to bring the metal to a shine. Then use polishing compounds for a reflective finish. I'm sure there is more information online if you look around.Last edited by e34///M; 02-26-2014, 01:02 PM.
on a scale of 1 to 10.... easily a 8.5....I do not recommend it. The worst part is how much you have to remove and you most likely will break your gas pedal (plastic). you just have to take your time.Originally posted by Stancyeze View PostWas it difficult installing the new carpet? I'm thinking of doing the same thing.
A lip would look good=) Max Velocity or AC Schnitzer would be good. Top looks great
You read my mind... I swear I got like 5 different ones in my watch list on ebay LOLOriginally posted by Earl View PostA lip would look good=) Max Velocity or AC Schnitzer would be good. Top looks great
actually the are Racing dynamics (RGP) they are e34 rimsOriginally posted by TruTaing View PostLooks awesome dude! Are those vette wheels?
got them off a buddy with a e34 M5
