Hi haha! This week I have more update.
I just got the 2.5" aluminum pipe so let make a air horn for my throttle.
Just do it by simple, flare and cut, that's it!
[img][img]
[img][img]
[img][img]
It just raw but I love it, next week will completeit 8 pcs.
Enjoy
Thank guys, I'm no professional too. I just think the important part for velocity long equal should be after valve. These air horn I attempt to complete decollate the ITB more than performance function. BTW, respect your!
Oh the stack issue!!!!
many opinions but the better is equal stack, about the resonance, pressure etc...
Thank you again...
Btw, I will keep kool first the healthy engine later
I had a conversation about velocity stacks with a friend who has a degree on engines.
He said that with part throttle the resonances come from throttle flaps. But on full throttle its the velocity stack ends that create the resonance.
Also you can use different length stacks to better the power curve wider area than equal length stacks. Then the stack lengths have to be paired with cyliders on same con rod journal (same phase).
-Timo
-------------------------------------------------------------------- Mushroom Motorsport - Performance since 2003
