Elder Scrolls VI: Pleiades 86 Subaru GL-10
nah, I'm gonna have to rebuild the motor at some point and I might just swap to a WRX turbo running like 7-10 lbs, I also got an EJ20 block so if the cylinder walls are good, Imma rebuild that and make POWWWERRRRRRRRR!!!!!!
"Nord's armor has lots of fur. This sometimes makes M'aiq nervous." -M'aiq The Liar
THIS GL-10 IS PRETTY COOL!
Stay up to date with my '86 Subaru GL-10 build on Instagram with @billytheboobaru
"At least if your car is going to die, might as well die under WOT giving it the beans"
Nice wagon! I see heaps of these in aus, but never noted a digital dash and would like to see how it turns out on the coils.....I agree ej25 block fill and drill the water galleys around the piston sleave and throw some fuel and pletty of FI into her and make some pwr
Well as far as coilovers go, I am going to run Miata rears, I need a set of miata coilover sleeves that can fit over OEM miata struts. For the fronts I am going to take the EF Civic coilovers I have in the back now and place them on my stock XT struts.Originally posted by 1jze30 View PostNice wagon! I see heaps of these in aus, but never noted a digital dash and would like to see how it turns out on the coils.....I agree ej25 block fill and drill the water galleys around the piston sleave and throw some fuel and pletty of FI into her and make some pwr
After I see how low this goes I plan on talking to one of the reps we got at work at BC and see about a set of custom aftermarket coilovers.
Thanks, Thats why I traded an AW11 MR2 for it.Originally posted by Darkyoshi154 View PostThis is soo cool, I've never seen one of these before."Nord's armor has lots of fur. This sometimes makes M'aiq nervous." -M'aiq The Liar
So here is an update, car should be running in about a week and a half, hopefully...
Anyway, here is what I got done...
Got a proper Coolant Feed line made from braided teflon coated hose from Pirtek, installing it into the car was WAY easier.
I can seperate it into 2 pieces too, here is how it looks installed.
Also modified a spare grille I had, need it to fit the horns into it so it needed to be cut. Plus, It does look cooler, going for an AE86 look.
before:
after:
Still gotta finish up the grille, I am going to clean up the melted plastic, basically cut out everything that isn't red, then going to fill in the sides so it looks a bit cleaner. Finally I will color match it to the car."Nord's armor has lots of fur. This sometimes makes M'aiq nervous." -M'aiq The Liar
Finished up the induction system for the most part yesterday, also got the spoiler back on. Alas I am once again at an impasse as I am stuck figuring out how to get the hood release cable routed to the interior of the car
In the meantime here are pics of my new fog lights that arrived on Friday, they're gonna look dope once I get them mounted onto the bumper.
Why have I not updated this?
Anyway, I have spent copious amounts of time doing random crap on this, I now am read to paint the custom grille and new bumper filler! I will update with pics once I get home!"Nord's armor has lots of fur. This sometimes makes M'aiq nervous." -M'aiq The Liar
I care guys haha, I promise. I just have an engine I have to make for my daily because it's beginning to burn oil. However big update. Not the EJ20, not yet. BUT I started it up to confirm everything works.Originally posted by rice4life View PostDo you not care about us anymore?
you need to build up that ej20 mane. I needed to know what head you're using.
I'm bumping this thread so you can get off your ass to update it maybe probably.
Don't mind the smoke, there was a lot of oil in the intake path and in the cylinders. The old turbo burnt a lot (oil, coolant, gas, money, etc) and this one should be mostly good, worst case scenario, I have a TD04L with a flange that I can fit onto the car.
Also, Miata lowering springs and struts are ready to go on. So after this post, I'm gonna poop and then get cracking on those."Nord's armor has lots of fur. This sometimes makes M'aiq nervous." -M'aiq The Liar
Also, The EJ will be getting built either this winter or next spring. I am thinking I'll use just some EJ205 heads."Nord's armor has lots of fur. This sometimes makes M'aiq nervous." -M'aiq The Liar
Subscribed because sweet subaru
and also from your neighboring state (South Dakota)
Yeah no downpipe and running like shit will do that to you. There is still a LOT of oil in the intake path.Originally posted by rice4life View PostKind of sounded like a tractor hahaha. Glad to hear it's still going.
This would look sooooo good on some SSR reverse meshes.
Oh sick man! I have a facebook for classic Japanese cars if you want to join here: https://www.facebook.com/groups/Japa...ssics/?fref=tsOriginally posted by cosmo135 View PostSubscribed because sweet subaru
and also from your neighboring state (South Dakota)"Nord's armor has lots of fur. This sometimes makes M'aiq nervous." -M'aiq The Liar
