89 bmw e30 solid bushes and heaps of lock
  • 89 bmw e30 solid bushes and heaps of lock
    so as promised in my "hello thread" a build thread its not so much as a build thread as its already done well not done but mk1 version is up and working great
    anyway the history is i bought the car over a year ago in a very sorry sate, needed lots of welding, bushes etc the previous owner was going the scrap it, so i saved it arse from the crusher, and have been abusing it on a daily bases ever since
    this is a short time after i bought it, notice the 4x4 ride height and the monstrous high offset wheels
    not long after that i got stuck into the welding and making it handle and look awesome
    so in comes a heap of solid bushes in the rear end,
    a e36 double wing diff cover with tigged in alloy bushes, which then mates up to a e30 medium case diff with a 3.64 ratio, which suits the m42 while drifting and general driving much better than the 4.45 that was horrible,
    For the sub-frame i had steel bushes machined so that they lift the subframe 12mm to reduce camber/ toe, does make a massive difference, along with new wheel bearings and trailing arm bushes the back end now grips like it should, and handles like it should, all the people that say solid bushes make loads more road noise are crazy my car is stripped out and i noticed NO difference in noise just the awesome handling
    heres the 36 diff cover with my custom bolt in diff bracket, not pictured is the crush tubes and spreader plate the sits above
    up front im running a e36 m3 evo steering rack with 5mm lock spacers, no p/s the very light m42 makes it way to light and had very little feel plus 5mm spacers pop the seals
    Strut wise im running e30 struts shortened by about 95mm and running mk2 golf dampers with weld on coilover sleeves along with modified ackerman angle and pivot point
    all that combined gives me plently of lock and alot better handling, i cant believe how good it drives/drifts ive drifted a few sorted s-bodies and this is just as good
    this is my front bump travel at my pretty low ride height, yes thats a full 5" problem is there's only 1.5" to 2" max of ground clearance haha
    anyway enough of the boring stuff now to the cool bits my wheels
    one day searching ebay for random stuff i came across a set of 4 jap 6 stud 3 piece split rims so i stuck on a cheap bit not rely thinking i would win then but dam i did at £43 haha so after picking them up seeing they was et-14 and 6x139.7 i hacked a plan on making them fit, rang up my machinist and got him to make a set of adapters up to take the stock 4x100 out to 6x139.7 and then set about making them fit at et-44 oops
    but results are this
    tucks lovely
    the front does need a splitter badly sit way to high
    got lock
    some more general drift pictures
    there is other bits and bobs which i will upload another day but for now what do you guys think
    The stupid is everywhere.
    i love it. drift rats ftw
    IG: Nick475
      Awesome car, I kinda want to make my e30 like this..
      I love the 6-bolts, they look great and it's just a cool thing to see. lol
      4 Cars, 0 Cupholders
        this car looks badass.
          Love it, miss my rust bucket e30
          Follow on IG
          amgwheelwhore
          Buy my wheels
          Vintage AME Wheels
          RUF Speedline Wheels
          Buy my cars
          W115 & W123
            Love this so far.
            E30 V8 Build thread
            Go here be happy!
            Instagram: stuartrussell
              seeing as your comments were so cool, ill treat you to a another session
              so for a drift oriented car coilovers are a clear and easy choice, but being a low e30 that brings up two main problems 1, getting hold of a set and 2, bump travel
              being as i don't want or have the money for of the shelf kits i decided to make some short strut coilovers, after much research i fount mk2 golf front inserts are the same diameter as e30s and are around 90-100mm shorter and you can buy adjustable inserts from GAZ for under £100, so i bought a set of ebay and set about making them fit, cue the A-team music, after some cutting and welding you end up with these i am yet to have fitted the adjustable inserts but they are needed badly.
              heres how short mine are against stock e30 struts
              and the finished item fitted
              due to the golf inserts being a m14 thread were as the e30 ones are m12 i had to have some special top mount bolts made in stainless as well
              i also cut up the knuckles while i was there, 0 ackerman, quicker steering
              so the solid bushes in the rear end, like i said before i had them machined with a 12mm lift to reduce camber/toe, pre welding
              and one of my custom solid bushes in the e36 double wing diff cover
                some cool photos from RRG13 so far, thanks to who ever has taken them
                Will upload some more later
                  Looks like fun. I like it!
                  E30 Buildthread
                  http://www.stanceworks.com/forums/sh...ad.php?t=34177
                  IG: Logyt
                  e28 sig by logyt, on Flickr
                    As much as I'm disgusted by rust, it adds so much character. This thing is sweet the Drift/Rat aspect is definitely a looker. Good work man.
                    [Cut. Weld. Scrape. = Bagged e30 Build Thread]
                    [Instagram: Ritchie_30]
                      That thing's nuts...
                        So last Sunday i went along to my favorite drift venue were ive spent many a hour over the last 4 years, a small banger track called Birmingham wheels, heading down the the motorway sparks flying form underneath as the exhaust carried on getting thinner loaded full of fuel, tyres and hopes of driving my daily home that night, so we get there and set up, sign on and i stick my car in the cue, ready for some action and action i got
                        with a few hours of tyre shreading, chasing down cars with three times the price tag and powers is allways good fun, quickly it was dinner time and time to get ready for the comp, realising i had only one decent set of tyres left my hopes were pretty low of getting far, my first battle was pretty easy the guy spun both times so i didnt work hard, then up against Magic in his 2.8 e36, hopes high we set of him chasing me first all goes well i think, second run chasing him i get pretty close then come in to the top corner and a small straighten from me and my tyres going off letting him run away from me handed him the win, was very good fun chasing a quick guy, somebody even manged to get a video sweet
                        so good days drifting no damage other than, two engine mounts and some arch damage but 10 dead tyres, car smelling of rubber i head of home very happy
