I found something I overlooked in my repair. Turns out I didn't only bend my tie rod, I some how damaged my control arm bushing. I discovered this when the center piece of it fell out while I was driving. Took me a little bit to diagnose the problem, but it was a simple fix. I got polyurethane bushings off ebay that seem to be made really well for less than I can buy stock ones at my work with my employee discount. you can hear and feel the road more than before with them, but I'm okay with that. the car should feel more solid and race car-esque when I drive it hard, and I want that.
so now I need to fix that annoying fan clutch, replace the diff bushings, and do some fab work to make my sway bar fit again. I also should replace my remaining original low pressure power steering line. I think that is the remainder of my leak with the system. I also want to put in a cone filter, mostly to start cleaning up the appearance of the engine bay.
lots of plans, but for the most part, I'm anxious to put miles on this car again.
