'86 Mr2
  • #61
    Originally posted by 74Mango View Post
    IMHO, get the silvertop 20V instead of the 20V blacktop, blacktop are designed for N/A, silvertop has beefier internals compared to blacktop, both engines are rev happy motors,
    gze is good option for boosted application, unfortunately in the long run it will cost you more.:
    how bout 3sgte?
    I can't lie, a 3s has crossed my mind many times. If I come across one at a good price, it may happen. Not really planning on going gze, if I boost it is going to be on the 16v 4age.
    Check out technotoy, they have lots of great parts there. The 20v's are waaaaay overrated. 4ag's make their power up at the top end, and a smallport 4ag can easily achieve around 160 at the crank with the right mods. It may not revv as high without mad modification, but the 16v's seem to feel a bit more torquey.
    Lightweight pulleys, flywheel, big bore throttle body, cams, bolt ons, and mild tune will make you more than happy with the little 4ag. The only thing 20v's are good for IMO are good gas mileage.
    Sorry for my rant. I love 4a's.
    Have you heard of the 2zzge swap? When they hit lift, it is orgasmic. Also, you can use the solid lifters from the echo engine on the 4ag 16v
    I haven't read much into a 2zz swap. I should look into that. What is the advantage to running he echo lifters?
    '13 Fiat 500 Abarth
    '99 E36 Convertible
    • #62
      Been quite lately. I picked up an e23 that I've been putting time into. Also done a lot of work on the girlfriends sw20. I have managed to pick up a new set of wheels for the aw11. 16x9.5 square salad shooters. Started painting them today, already had the centers bored to 72.5 so the adapters will fit other bmw wheels as well. I am thinking black slots will work well with this random cream color I went with.
      '13 Fiat 500 Abarth
      '99 E36 Convertible
      • #63
        nice!!! glad too see some more old toyotas!
        you're making me want one even more hahaha. 13s go rad on lowered cars.
        • #64
          You're doing things right!
          - Garrett
          @mtm_garrett on Instagram
          • #65
            Little Aw11 secret from a PO: Nissan 2wd truck clear front turn signal lenses are a direct swap. cars lookin great. Makes me wish I took my spoiler off when I had the chance.
            • #66
              Really liking this build
              Sent from my HTC 3D using Tapatalk 2
              • #67
                Thanks for the compliments. anyone have any ideas on adapters for a car with studs and not lugs? I bought a set but they were lugs that bolted them to the hub and that won't work. I also don't want to spend 400 bucks for custom ones. I may have to.
                '13 Fiat 500 Abarth
                '99 E36 Convertible
                • #68
                  This looks sssooo good, I love it!
                  • #69
                    Please stay with the 13's
                    They're perfect.
                    • #70
                      With the 13's I wanna go lower, but I am all the way down with no adjuster rings and the spring pre-loaded to no threads left on the strut. That is why I picked up the salad shooters. Plus they are an inch and a half wider all around
                      '13 Fiat 500 Abarth
                      '99 E36 Convertible
                      • #71
                        Did a little more work. Poly steering rack bushings, sway bar bushings, and forward control arm bushings as well as some paint while I was at it.
                        And a cool night shot my girlfriend took recently.
                        '13 Fiat 500 Abarth
                        '99 E36 Convertible
                        • #72
                          Really liking this. The tails came out really neat.
                          Clover | 1992 Mk2 Jetta clx - Build Thread
                          Cape Town | South Africa
                          Instagram: @lowdl
                          Tumblr
