[ame="http://www.youtube.com/watch?v=pFrbFa5_tck"]Mindy's Reincarnation - YouTube[/ame]
(Watch in HD)
Internal Engine
S52 Head Ported w/ Mild Port, Polish & 5-Angle Valve Job
S52 Camshafts
1/2" ARP Headstuds
Elring Head Gasket
O-Ringed Block w/ .051" Stainless Steel @ .010" Protrusion
Custom Wiseco Turbo Pistons
8.8:1 Low Compression
85.217mm Overbored M52 Block
S52 Crankshaft
K1 Connecting Rods
Standard 89.6mm Stroke
3.068L Total Displacement
.0035" Piston To Wall Clearance
.0180" Top Ring Gap
.0200" Bottom Ring Gap
OEM Main Bearings
ARP Main Fasteners
Glyco Main Bearings
Glyco Rod Bearings
Turner Motorsport Oil Pan Baffle Kit
Welded Oil Pump Nut
20W50 Dinosaur Oil
External Engine
SPA T3 Turbo Manifold
SPA 7000M 65mm Turbo
Tial MV-S Wastegate
Key Components Ceramic Turbine Coated
M50 Manifold w/ Taps
2.5" Hot Side Piping
Treadstone TR1035 Intercooler
3.0" Cold Side Piping
Synapse Blowoff Valve
Fuel / Engine Management
Dual Aeromotive 340LPH Fuel Pumps
2x 5/16" Goodyear High Pressure Fuel Feeds
5/8" Primary Fuel Line
Aeromotive ORB-10 Fuel Filter
Rally Road Fuel Rail
115# Bosch Motorsport Injectors
Aeromotive A1000 Fuel Pressure Regulator
1/2" Fuel Return Line
NGK 4554 Plugs w/ .020" Gap
Factory DME Tuned By RK Tunes (OBD2 Compliant)
Exhaust
3.0" SS Primary Midsection
1.0" Open Wastegate Dump
Split To Dual 2.5" SS Pipes
Dual Magnaflow 14816 Mufflers
Drivetrain
UUC Twin Disc Feramic Clutch
Rally Road Stainless Steel Pivot Pin
AKG 80D Poly Transmission Mounts
Rally Road Steel Transmission Crossmember
BimmerDiffs.com 4-Clutch 2.93 Differential
Amsoil Syncromesh 5W30 Transmission Fluid
Amsoil 75W140 Severe Gear Differential Fluid
Wheels / Tires
Fikse FM-10 17x9 Front & 17x11 Rear
Toyo 888 Tires 255/40/17 Front & 315/35/17 Rear
Suspension
Koni SA Yellow Struts / Shocks
H&R Sport Springs
H&R 28mm Front Swaybar
H&R 21mm Rear Swaybar
Eibach Lightweight Strut Bar
Ireland Engineering Race Poly Subframe Bushings
AKG Poly Rear Trailing Arm Bushings
AKG Poly Motor Mounts
TRM Turbo Motor Mount Arm
Ireland Engineering Weld-in Camber / Toe Correction
Rear Subframe Reinforced By Piper Motorsport
Custom Coated Brake Components
Valvoline DOT5 Brake Fluid
Motion Motorsport Z3 Aluminum Undertray
Interior
HKS EVC-6 Electronic Boost Controller
AEM Gauges (AFR / Boost)
Innovate Motorsports LM-2 Wideband Controller
Sparco 330mm Lap Steering Wheel
Bimmerdiffs.com Seat Bushings
Bimmerdiffs.com Seat Mod Kit
Exterior
Rear Wiper Delete
Shaved Front Bumper Lights
I couldn't have a bigger grin on my face while posting this!
~ Jonathan Thayer
(Watch in HD)
Internal Engine
S52 Camshafts
1/2" ARP Headstuds
Elring Head Gasket
S52 Crankshaft
K1 Connecting Rods
.0180" Top Ring Gap
OEM Main Bearings
ARP Main Fasteners
Glyco Main Bearings
Glyco Rod Bearings
Welded Oil Pump Nut
20W50 Dinosaur Oil
External Engine
Tial MV-S Wastegate
Exhaust
Drivetrain
Wheels / Tires
Suspension
H&R Sport Springs
Interior
Exterior
Rear Wiper Delete
~ Jonathan Thayer
