Oh gawd another 02 build!?
  • Oh gawd another 02 build!?
    hello guys
    My name is tixoc pronounced Teeeee Zock.... yeap i know, its aztec and i am 20 years old.....
    this is my first project and i just learned as i go... just used simple logic and learned how to weld through this thing called youtube... and google, good stuff
    I have finally decided to post my build... I bought this 02 last year in december and i guess ill share my ideas....
    So i bought this baby
    day 1
    looked good at first next to my e30 m50 swap
    started taking shit apart
    bad news bears
    shit load of rust
    started cleaning
    test fitted some stickies
    cutt the front off going to make it removable
    was going to a ls1 route but the machine shop offered me money for the longblock for their drag car so i couldnt refuse and sold the ls1
    ripped this bitch out cuz its blows like da sum ass
    modify the e30 rear subframe to fit the 02 stock mounting points.... was a bitch but got it centered
    started making mounts to hold the front bumper
    okay now fast forward more.....
    subframe mounted so far... see goes into stock mounting points NOT HARD..... kinda
    also purchased ireland engineering full rear coilovers also i welded on camber and toe adjusters in the rear.
    BAM SON installed...
    welded the strut towers together because 02 chasis are weak sauce and like older than me
    GOTA REPRESENT!
    started to fix the rocker panels with new sheet metal and reinforced with 3/16 L iron angle thing...
    then i picked up a s52 with 80k miles.... yea i know low!!! just how i like them
    then one day i was like lets mount this bish i pushed the engine 3 inches back so weight distribution should not be tooooo bad, hatters suck on my nut (no shits given)
    made some mounts and use a m20 condor speed shop solid mount
    used stock m10 mount located but solid mount
    then i purchased tii struts with e12 hubs for 5 lug swap and bilstein valved struts with 350 spring for the front
    then got a free 4.10 LSD diff son!!!
    my awesome 16 guage galvinized hot dipped steel sheet metal for rust repair omg it sucks
    how it sits now
    reverse rake son! oh yea i also made flares... they go out 3 inches still not finished i am going to extend them and make them look nice
    oh yea its on ac shinzters type 3 17x8.5 et14 wrapped around 255 tires
    and the front will be the same wrapped in 255 aswell
    oh yea inside the cock pit
    i need to mounts these one day
    so thats it so far.....
    Today i just ordered a 300mm willwood big brake from ireland engineering for the front so i should get that in a week.
    so my plan is clean/rust repair
    coilover mod for tii struts
    fab a transmission tunnel
    more rust repair/clean and more and more...
    remove s52 paint engine do some preventive maintenance.
    refresh front subframe
    once everything is finished
    interior time/ first start!
    rollcage
    then paint, i dont have a clue what to paint it. i was thinking like grand prix white or a jet black but we shall see ....
    then time to track this bitch
    Nice start and very promising work, but those wheels are way too big and look hideous. I hope a mod bans you for that thread title.
    Volvo Build Thread
    Bmw Build Thread
    Toyota Build Thread
    zanebonk instagram
    Tumblrrrr
        i was pretty lazy this weekend and didn't do much except for the shortening the struts, them came out decent. enjoy
        just got to buy new bearings for the 5 lug hubs and press in the hubs and install 300 mm will wood brakes that are on the way from ireland engineering! those guys are awesome.
          i like where this is going, keep up the good work !
              That's quite a bit of rust... good luck fixing it up!
                lol yeap, most of it is gone now but still finding random places can be a pain
                  just received my 300mm bbk from irelandengineering!!! i am so excited to drive this thing.
                  255 tires in the front
                  driver side floorpan since the old is is bad and frame rail completely rusted
                  coilovers installed
                  took out the s52 today going to clean it up paint, re gasket it
                  fabed up a new floorpan
                  driver side
                  i am going to try to finish the driver side tomorrow and drop the front subframe for a complete refresh and clean the engine bay.
                  finished the floor
                    I subbed so hard it hurt! I can't wait till I can afford a 2002 and start my build... lol
                      DuWERK
                      R.I.P P.WALKER 2013/11/30
                        holy fab work batman! I'm interested to see where this goes
                          Wow this is a very promising build
                          This is my signature
                            more pics from today
                            wire brushed with before and after
                            boxed in control arms and seam welded
                            refreshed the whole front sub frame
                            i used ireland engineering poly bushings for everything on this car so far, thanks again Ireland engineering
                            I also started to clean the engine bay and start the shaving process XD, i will post pics later im pooped :yawn:
                              clean inside
                              dirty pistons but clean bores
                              head is off
                              cleaned the pistons and the deck
                              wrinkle engine cover
                              New water pump
                              new housing
                              painted the block, came out okay
                              VAC Oil pan baffle for autox and track
                              oem headgasket and other goodies
                              stay tuned for this weekend
                              its been while since i updated this i will show where i am at
                              i already re-gasketed the s52, timing cover, headgasket ect whole nine with oem parts from bluntech.
                              after doing the engine i finished the engine bay by grinding it down and brushing on this special clear coat design to protect metal but give it that bare metal look. it looks great!
                              when the engine bay was done i decide to drop in the engine and try to start it. I got everything in and pluged up but only thing from keeping to start it is spark plugs and connecting the fuel pump up. other than that it cranks and i can hear the icv huming so that means its good soooo far.... lol i will find out soon
                              onto the pics
                              modified firewall
                              e39 m5 cyclone separator, supposedly a lot better than the stock separator
                              stuff i used for the bare metal look, i brushed it on and left no streaks, awesome product
                              oil pan clearance and its not even fully lowered
                              not much clearance for the boot heheh
                              bare metal finish
                              more bare metal finish
                              in all her glory
                              used mini cooper belt
                              inside
                              going to buy spark plugs and hook up the fuel lines and we shall see what happens cross fingers!!!! hahhhhah *screaming like a lil bitch*
                              as far as plugging up the s52 ODB2 into a 2002
                              x20 bmw 2002 harness
                              alt 25 > blue wire that is in the voltage reg
                              ignition 21 > green wire inside the firewall or the green wire behind the ignition starter
                              starter 15 > ground
                              starter 18 > pin 50 behind the ignition starter
                              fuel pump 13 > direct to fuel pump i am using a 318is from a e30 with pick up
                              and it should work, with this done i have the icv hum and crank. i just need to plop in some spark plugs and give it gas and it should be on like bing bong jack!
                              hopefully people can take advantage of odb2 and not convert to odb1 which is stupid, only gain you get is odb 1 intake manifold other wise a down grade
                              these are what i used for hooking the s52 up
                              odb2 x20
                              ms41.1 dme pin out
                              the rest is easy and hooking up gauges to the x20 or whatever your using
                              i am using a ms41.1 ecu odb2 from DesertBMW ews delete, tune rear o2 delete and much more
