L3GIT MS3 (this is not really a build thread)
  • L3GIT MS3 (this is not really a build thread)
    My car is a Crystal White Pearl 2012 Mazdaspeed 3 non-tech pkg. She's daily driven and daily scraped.
    This was the morning after I picked her up, barely knew how to drive stick but I made it to the train station somehow.
    My wonderful girlfriend bought me coilovers for Chrsitmas! Granted they aren't the best they do the job.
    So my friends and I installed them in his warm garage, and spun them all the way down.
    The white piece abovein front of the spring shows a pinch weld that forced its way through the fenderwell and had to be flattened so it would stop trying to kill my tire, it was done to both fronts.
    This is how she sat right after installation and a quick drive to try and settle the springs.
    A few random shots of her sitting pretty
    Then I found these on Craigslist...18x9.5 +35
    They poked a lot in the front on the initial test fit so we rolled & pulled the front fenders.
    The new test fit on the fronts looked like this. I literally have about 3mm of clearance on the inside and will prob run 10mm spacers with 3* of camber
    Tires will be 225/40
    I have also removed the rear seats but plan on putting them back in soon.
    As for performance the car only has intake/inlet and rear motor mount and on stock tune is running 272whp/292wtq on a dynojet
    More updates to come
    All comments both good and bad are welcome (I have a tough skin)
    in for updates
    IG: Nick475
      Updates:
      So after this happened
      this happened
      and I like it but it rubbed worse than a fat chicks thighs
      then while parked at the train station one day I cam back to find this
      so I order this
      then I finally got around to the important stuff so I ordered these (ignore the creep)
      and these
      235/40's
        moooaaaarrrrr!
          Then I got tired of looking at the green wheels and did this
          which turned into this
          got them mounted, did some fender work and threw them on the car
          Left it at stock camber maxed out rear coilovers and raised the fronts a bit for an even drop to get this
          Rear
          Front
          Profeshon-Al photos from my buddy Deebs
          Thanks for looking any comments positive/negative are welcome!
            pretty solid. i like the bronze on white a lot. but i think the stickers on mirrors really take away from cleanliness of car.
            025garage
              nvm pics work again....
              I'm working on the stickers I'm not really going for the clean look but the stickers have caused me enough trouble anyway
              Thanks for the kind words!
                Just a couple shots from last night's mini photo shoot with a friend
