Awesome read...all the small details make the car what it is in my opinion. Those OZs and that Nardi wheel will look so good man! What are you planning on to get lower?
HYPETODAY // '89 Mercedes-Benz W124 260E
thanks, guys!
at first i will change the original spring rubbers. which are available for this car in 4 versions. depending on the equipment, mercedes has previously installed differently thick gums. i get the thinnest. which again makes about 2 centimeter difference. because of the new wheels, also the rolling circumference is smaller. then we'll see. i need also shorter shock absorbers. we will make some new and shorter ones. unfortunately i'm still waiting.Originally posted by keeton View PostAwesome read...all the small details make the car what it is in my opinion. Those OZs and that Nardi wheel will look so good man! What are you planning on to get lower?
If you manage to do that (the short shocks), I would like a set of those too
Lucas
Ah those ones. Couldn't find them anymore last time I looked. But thanks for the link!
Oh btw: are you sure? because I think the coilovers will not work as the top linkage in the wheel well is too weak to hold the pressure
EDIT: Forgot the camberplate. Never mind
@MikeyRa:
That's great! I'll might try that.. And then use E36-shocks in front....Last edited by loekaaz; 06-13-2013, 11:40 AM.Lucas
there is something in germany.. it's called tüv!
Originally posted by MikeyRa View PostUse 1995 Ford Ranger 2wd 4cyl front shocks for the rear of the w124. Comparison shot:
Sent from my SGH-T959V using Tapatalk 2
those work on a benz huh ?
super small update.
today I picked up my car. a nice difference since the start and now. i hope that on the weekend the wheels can be mounted. let's see if i have time.
it's a long way, there's more to come! hope you enjoy the thread!
Or R129 upper strut mounts for the front.Originally posted by loekaaz View Post
@MikeyRa:
t
The sure do, I lay rear diff with these on the rearOriginally posted by SD202 View Postthose work on a benz huh ?
Sent from my SGH-T959V using Tapatalk 2Instagram: @Eurow
You need the Sacco Bretter side panels...
Lucas
nooo... less hidden surfaces - less rust.
i also do not want to drill 11 holes in my sill for the cladding.
You do not need to drill anything. You can use the original holes. At least, that what the PO of mine did.....Originally posted by hypetoday View Postnooo... less hidden surfaces - less rust.
So it should not make any difference compared to the original situation..Last edited by loekaaz; 06-18-2013, 09:20 AM.Lucas
Looks sharp! I really like the shift knob/boot combo you made. Can't wait to see it with the wheels and coilovers.
Just a question- In Germany do you get to choose if you want the long "traditional" plate or the ones you have on now?Instagram: @HOONResponsibly
