Hey guys, ive been roaming through the pages of stance works for some time now, but never posted all that much, but i figured because im doing a build this winter i might as well make a thread and share with ya'll what im doing. heres how the car sat last fall when i bought it
2000 VW GTi 1.8T
and heres some of the progress ive made in the past few months. its been slow going because im a college student and only make it home every other weekend to work on it.
to do list
Bay
• Drill holes for harness
• Remove unwanted bay cosmetics and fill over
• Fill in uneeded holes
• Weld over seems and smooth out
• Grind down ridges
• Notch frame
• Remove sway bar
• Prime
• Paint
Wiring
• Extend remaining wires of fans
• Extend drivers side head light harness
• Extend wires to control module
• Loom body harness and install quick disconnect
• Engine harness 1: solder in resistors and wideband conversion
• Engine harness 2: extend needed wires and test route wires
• Loom engine harnesses
• Run wire for battery relocate
• Finish trunk battery mounting location
Other
• Black out head light housing
• Install coils
• Roll fenders
• get stanced
ill update as often as i can and make as much progress as possible! enjoy!
2000 VW GTi 1.8T
to do list
Bay
• Grind down ridges
• Notch frame
• Remove sway bar
• Prime
• Paint
Wiring
Other
• Install coils
• Roll fenders
• get stanced
