My 1987 budget Camaro build
  • Btw :
    Got my bumper mounted
    Current state of the dash :
    Waiting from leds @ chicago.
    Done some touch up, will put sticker anyway
    The old coolant tank had rub all the paint. Good job GM.
    Overflow tank in place
    • Tested rear relay for the trunk
      Had to crawl on trunk, remove light and disengage the trunk with a flathead screwdriver, you can see key release unbolt.....
      You can see dust.... shame on me
      3 years without seeing this.
      Damn a garage is usefull !
      relay seems to have "vers de gros cris"
      • Washed the GF car
        Changed the orange "redline"
        Need to put the rear on candellas.
        Weightreduction
        Wiper motor.
        Spindle mod.
        Before with the C shaped part
        After ("C" shaped part to bolt the bracket)
        The only thing left is to "tape" holes for the Galiper bracket and torque wheels studs
        • Car will stay like a long time.
          Rear brakes removed, got diff oil, it's sticky.
          • Diff had a lot of loose on the shaft
            Problem was the counter-bore needed to be before the Caliper plate
            Before :
            After :
            You can see the sandwich
            But the disk is not enligned and hit the caliper bracker right now :
            I will need to shim the disk hub.
            Testing how much shim I need
            I will need to put 3'' studs in remplacement of the cutted 2'' because the new 0.5inch spacer will not have it's own studs.
            With the shim everything will be fine. Wilwood don,t give a shit about 12bolts Strange diff and their kit. The offset of the axle is incorrect
            Bracket it now enligned.
            Ticoune stickers koz I'm a fucking ticoune
            • Not going to lie I really don't like these 80's chevys, but this is the cleanest one iv ever seen! Car looks grate! Glad to see you going through the brakes and suspension and not just putting more power into the car. This is how I would have done it if I had one!
              Also a cool idea with the hoonigan sticker I might borrow that idea down the road if you don't mind.
              Instagram @Petrol360
              88 RX7 FC 5.0
              77 Yamaha XS400
              • Originally posted by Skervey View Post
                Thx for your great comment
                For the sticker, go ahead, but you'll need to show me once it,s done hehehhe
                • Originally posted by paradigmqc View Post
                  LOL! this made me laugh. Props for a local build. Got some plans over the winter thats coming? I wish I had a garage too.
                  Ruining cars since 2006 yo
                  • Originally posted by Meeve View Post
                    Thx
                    Got a lot of plans :
                    Oil filter relocator
                    Oil change
                    New rear tires
                    Redo the letter in yellow on my tires
                    Redone may spark plug wire with the heat shield
                    Change safety belt for black ones
                    Change speedo cable
                    Ajust trunk
                    Wilwood proportionning valve
                    Line lock
                    Finished the install of the brakes
                    QA1 Coilovers
                    Yesterday I finished to install the front caliper bracket.
                    Tapping a hole is not easy for the first time, not enought deep lol. I need a new bolt.
                    Done :
                    Still waiting for the rear disk hub spacer , but I moked up the shit.
                    Look cool
                    Dunno I told ya guys, but I changed my DD, I had an 06 Altima on BC coilover.
                    I bought an 2010 Maxima
                    • Specs of the car so far :
                      :: Engine ::
                      Chevy performance crate engine
                      Edelbrock Performer RPM intake
                      Holley 600CFM Dual pump mecanic secondaries
                      MSD Streetfire HEI distributor
                      Taylor 8MM cable
                      Spark plug cable heat shield
                      Becool 3row crossloop radiator
                      Flex-a-lite black magic fan
                      GM performance Black valve covers
                      Holley Ajustable kickdown / gaz cable adaptor
                      Mr gasket water elbow
                      Racing damper
                      Ebay ajustable alternator bracket
                      Moroso overflow tank
                      Oil filter relocation
                      Aem Wideband
                      :: Exaust ::
                      Hooker Competition 1 5/8 headers
                      Hooker competition Y pipe
                      Dynomax mandrel line
                      Dynomax superturbo Muffler
                      Flowmaster 4'' tips
                      :: Drivetrain ::
                      Built Th700r4 with shiftkit
                      2800 stall from 2006 corvette
                      Custom built driveshaft
                      Strange Engineering 12bolt 3.73 gear fullspool street gears c-clip eliminator
                      :: Suspension / chassiss ::
                      Tokico bluehp shocks
                      Eibach prokit coils
                      UMI wonderbar
                      QA1 Strustbar
                      UMI ajustable panhard
                      Lakewood LCAs
                      BMR ajustable torque arm
                      Poly link kits
                      Poly Engine mount
                      Poly torque arm bushing
                      Steel tranny bushing
                      Hotchkis Frame connectors
                      :: Brakes ::
                      Wilwood 4 piston front
                      Wilwood 4 piston rear
                      Wilwood proportioning valve
                      :: Wheels / tires ::
                      Cragar Soft8 17'' 8''Wide front
                      Cragar Soft8 17'' 9''Wide rear
                      Mickey thompson Street comp 245/40/17 front
                      Mickey thompson Street comp 275/35/17 front
                      :: Interior ::
                      Black seatbelt
                      All dash leds
                      3 pods gauge
                      Removed heat control
                      Aem Wideband gauge
                      Temp gauge
                      Oil pressure gauge
                      Voltage gauge
                      Classic industries Z28 floor mats
                      Removed T-top voute
                      :: Body ::
                      Redone car paint in 2010
                      Removed side moulure
                      Brand new Z28 logos
                      Rolled fenders
                      Sparco tow straps
                      Goodmark 4'' Cowl induction hood
                      New hand doors
                      Already miss the summer :
                      • (ba da da da daaaaa! im lovin it)
                        usually not one for camaros (jdm life) but this one is pretty sweet. Keep it up bro
                        • Originally posted by DukeNukeEm' View Post
                          Always cool to have this kind of comment. Thx men.
                          Which one ?
                          1.
                          2.
                          3.
                          • Longer wheel bolt done. 3/8X20 3'' grade 8
                            Sandwich done, plenty of threads left.
                            As you can see.
                            Car is still on 4 blocks
                            The sticker will be lower and the "But this sticker is awsome" section will be cut.
                            I will not do that, I will put that sticker somewhere on the garage.
                            Then it snowed for the first time of the year.
                            After that we drank.
                            • Need teflon.
                              Another ticoune sticker
                              Not that bad from the driver position
                              Ticoune sticker again on the geurage
                              • Received this....
                                Fuck this shit
                                Propo fitted
                                Oil filter relocation WIP
                                Test fit.
                                Will wrap the headlights today
                                Oil filter done.
