Woot woot! I want to get some proper shots at SoWo this year!
Korean Air
 love it man ! absolutely love it ! And how did you like the install on that v2 . super easy wiring wise huh ? Have you put any miles on the air ride yet ? How do you like the ride comfort and such. its nice huh.
 Originally posted by SD202 View Postlove it man ! absolutely love it ! And how did you like the install on that v2 . super easy wiring wise huh ? Have you put any miles on the air ride yet ? How do you like the ride comfort and such. its nice huh.I can't comment on how Gene likes the ride, but I can say this is the second v2 setup I've done and it's just flat out awesome. Simple and quality product for sure.Originally posted by Skraight. View PostAwesome, I hope I can get mine installed as fast as you did. I only have 3 days to do it so hopefully don't hit any snags.
 Would like to know what you think about the questions SD202 just asked as well.
 Yeah it's so awesome and easy to install! I used UAS 75559(HI damp) and they ride like high end coil... They make my Form & Function coils feel like cut springs.. They're stiff and properly valved for a firm, but comfortable rideOriginally posted by SD202 View Postlove it man ! absolutely love it ! And how did you like the install on that v2 . super easy wiring wise huh ? Have you put any miles on the air ride yet ? How do you like the ride comfort and such. its nice huh.
 Well, the reason we got it done in such a short time is because we worked from 9-10am thru 3am and all the way til 5:30 on monday. It wasn't easy to say the least. and not to be negative (i hope your install is smother), but we ran into several snags. So, Just-in case be preparedOriginally posted by Skraight. View PostAwesome, I hope I can get mine installed as fast as you did. I only have 3 days to do it so hopefully don't hit any snags.
 Yeah its really simpleOriginally posted by aLaFleur View PostI can't comment on how Gene likes the ride, but I can say this is the second v2 setup I've done and it's just flat out awesome. Simple and quality product for sure.
 the rear setup design is simple, but time consuming since we had to remove the entire upper spring mount and cut out the bottom cup on jack stands. The front alignments and etc and rear top hats is where all the planning and time goes.. You have to check clearances and stuff which can be tedious, but not bad.. I re-used the rear shock which prove to be a dud with my fronts. So, I called BC Racing and i'm going to have a set of custom valved shocks made to compliment my Air house 2's; as of right now the rear is bouncy. They're not valved for such high ratesOriginally posted by Chuckdee View PostYeeeeeeeeeeeessssssssssssssssssss finally pictures!!! That set up is looking mean, I'm curious about the rear setup though...?
 Better pix as promised:
 I'll be able to lay frame once I get my wheels on and slightly grind down the stock axle notch.
 R.I.P P.WALKER 2013/11/30
 so damn sexy, now get crackin on them wheels my dude !
