1978 Chamonix e21 BMW 316
  • #16
    This things so sweet,
    Also your friends photos are great. The editing really suits the car!
    • #17
      so, classy
      R.I.P P.WALKER 2013/11/30
      • #18
        Originally posted by Dirtyhands View Post
        So did you use mk2 rear coilovers on the back?
        Any modification needed?
        Yes, I used mk2 coils in the back. They were shortened by 110mm- piston rod along with the housing cylinder, to avoid change in the shock travel. (check pictures in my top post)
        I also had to grind off few mm of the inner tube in lower mount (not sure how it's called) in order to fit it into trailing arm fixing point.
        my '78 BMW e21 build thread
        • #19
          Originally posted by adatas View Post
          ohYES
          • #20
            GREAT JOB Great job
            • #21
              Thanks a lot for appreciation, stance peeps
              • #22
                that steering wheel is fire!!
                • #23
                  Great work, love euro e21s with the 2 big headlights up front. Really enhances the timeless shark nose.
                  • #24
                    Amazing E21 !
                    Gold BBS RS on a white car is gorgeous
                    FYI, Golf MK2 Rallye (or Syncro) coilovers don't require modifications to be installed in the rear of an E21, that's what I was running when I was on coils
                    Did you use 6cyl strut housings in the front? Because I am interested in the 5 lugs and 280mm brakes conversion using E23 parts
                    Enter the E21st century
                    • #25
                      Yes, I used struts from 323i at the front.
                      • #26
                        Best model BMW. You practically did nothing and it looks fucking rad.
                        • #27
                          taste sensation.
                          • #28
                            nice!
                            • #29
                              Im obsessed. been thinking of a white color change. this car makes me impatient.
                              W123 BUILD
                              500SEL BUILD
                              • #30
                                And this is how the car looks like now:
                                Nardi Classic 380mm Black Leather steering wheel with custom hub:
                                More photos in my flickr gallery
                                And short video for the desert http://youtu.be/T4M6kOZuj1s
                                Hi there, i m searching for steringwheel Nardi like your, But dont apear like yours on 380mm. Are you sure about dizer, isnt 390 ir 370mm? Thanks
