So I have been thinking about how I could fix the shift carrier issue and last night I came up with a solution. I have 2 extra m42 shift carriers sitting around, so I went to work with them.
G240 shift carrier, a couple inches longer than the g260
I cut it in half, and then put it in the car, made some measurements, lined it up with the center of the hole, and marked it up. If the arm is cut in half and then slid over, this puts it back towards the center of the hole for the shifter and corrects the offset issue. However, I still was stuck with the 10 degree issue of how the g260 sits with the m50. I am not done making the arm, but I grinded a little bit off of the bottom and when I bolt the 2 pieces together, it should come out to correct or come close to correct that issue.
Also took the differential apart and replaced the seal.
Next up is to finish cleaning up the wiring harness. Can't wait to get back in this thing and drive it.
She runs now after I fixed a vacuum leak.
