Just went through the whole build, incredible car man! What does your family think about the car now
My EBP Turbo Galant
Quick update. I havent updated in a while and for that I am sorry.
Switched up the wheel/tire setup again. 18x9.5 +15 Ambit RT8 wrapped in 245/40/18 Yokohama ES100. I also fabricated a new exhaust in form of a straight 3" side exit.
At Wekfest Chicago
I always do a photoshoot on the first day I drive her on the street.
Starting to play around with my cameras video ability and the new slider I picked up
Boost leak tested the car and found the MBC was leaking so I ripped it out and have the car setup to run wastegate pressure at the moment.
I need to wire the stock EVO BCS so I can run a Grimmspeed 3-port and use the boost by gear feature. Hoping to cut my 2.8" 60' and clock off an 11.0 pass.
Sub'd for 4g support
conversion syndicate*
4g63 swapped Hilux: http://www.stanceworks.com/forums/sh...ad.php?t=75423
ig: makercruuz
Quick photodump. Havent updated in a while. Switched up the wheels from the 18x9.5 Ambit RT8 to 17x9.5 Enkei RPF1.
I also set out to race the car this summer. BUT life threw me curveballs all summer so I wasnt able to get out to the drag strip until recently. I bought a set of 24.5" MH Racemasters and loaded the car up on the trailer.
No changes from last year except the slicks. Wastegate pressure (20 psi). Best time of 12.3 @ 117 with a dreadful 1.9 60'
Going to give it a bit more power up top and see if she can go faster. Pretty happy with her at the moment.
Well, this day was coming sooner or later, but the trans finally had a catastrophic enough failure that our racing season ended a bit early. 2nd gear wont engage in higher RPMs. Im pretty much done with this 3g trans. working on getting a FWD converted EVO trans setup to work with the Galant. We wanted an 11 second pass but the car just didnt have it in it with the current drivetrain.
Enjoy the video.
Next up 600whp and 10.99 1/4 mile
A lot of the reason Im shying away from AWD is the price, but I also like FWD racing. Locally, I can run a really competitive class every month if I stay FWD. The AWD classes usually doesnt have enough attendance to make a class.Originally posted by Tate View PostSince you are looking for an EVO fwd trans??? Why dont you just go AWD?
Is the price difference too large? Or?..
Is there a specific reason why you want to stick with fwd.
IDK
I am kinda contemplating it though....
On the verge of being Stanced
