Originally posted by NeilP
View Post
MGRAND3 the build of my e36 M3
thank you
IMG_20140729_210811 by MGRAND3, on Flickr
My build thread.http://www.stanceworks.com/forums/sh...ad.php?t=33607
Instagram: MGRAND3
im getting closer than ever to my desired look, I'm so excited to finally have the car headed in the direction I have envisioned for so long.
ordered some spc camber arms for the rear
IMAG0470 by MGRAND3, on Flickr
i finally got my faces back from my friend chris and ther are beautiful, especially for the first set of wheels he ever powdercoated. the faces are a metalic rootbeer color. my phone just sucks so they look black in some pictures
wheels stripped
IMG_5008 by MGRAND3, on Flickr
IMAG0446 by MGRAND3, on Flickr
then got some tires mounted on them. 205/40 federals
IMAG0458 by MGRAND3, on Flickr
IMAG0459 by MGRAND3, on Flickr
fronts are on, needs some tweaking and to slightly lower it but beside that I'm happy
IMAG0463 by MGRAND3, on Flickr
IMAG0465 by MGRAND3, on Flickr
IMAG0466 by MGRAND3, on Flickr
going to try and install the camber arms and do fender work in the rear this weekend.
Instagram: MGRAND3
i got tired of the white. i think once i have it all setup right the new wheels will look greatOriginally posted by xXp_ExoTiic_qXx View PostI preferred the old colour more :-/.
Instagram: MGRAND3
well I have been slowly working on the car recently.
IMG_20140626_161819 by MGRAND3, on Flickr
here is finally a picture good enough to show the color of my wheels
so i installed my spc camber arms and i decided to change my trailing arm bushings and modding the carrier to allow zero toe in with the negative camber i need.
IMAG0515 by MGRAND3, on Flickr
my modified, and slotted carrier, courtesy of my friend and great fabricator Jason Noren.
he is a tig master, stacking dimes
IMAG0517 by MGRAND3, on Flickr
After a quick spray for durability
akg trailing arm bushings in place
IMAG0518 by MGRAND3, on Flickr
all assembled
IMAG0519 by MGRAND3, on Flickr
IMAG0520 by MGRAND3, on Flickr
I decided to finally address my brakes. decided to go with stoptech slotted rotors all around, paired with stoptech street pads. I may get stainless lines and motul rbf600 brake fluid aswell.
IMAG0521 by MGRAND3, on Flickr
my wheels should be on next week. i still need to remove the sealant on my rear fenders and do some fender work and get an alignment.
Instagram: MGRAND3
rob I'm trying but I don't work as fast as you lolOriginally posted by Rob&co View Postmore!
Instagram: MGRAND3
ohhh and I forgot I received a package from ecs tuning with my new fog light covers and a replacement grill for my bumper. i also finally pulled the trigger on something I've wanted for the last 4 years, an ltw high rise from Abraham's Motorsports.
IMAG0522 by MGRAND3, on Flickr
IMAG0523 by MGRAND3, on Flickr
ohh and as soon as the car is fitted its going to the bodyshop for some touch ups and for the wing
Instagram: MGRAND3
Instagram: MGRAND3
thanks man.Originally posted by WunnabeM3 View PostThis thing is sick! Love the wheels.
Instagram: MGRAND3
well the wheels are finally on my car
IMAG0575 by MGRAND3, on Flickr
that rear fitment courtesy of Fendarolla and Broadway static
IMG_20140724_203947 by MGRAND3, on Flickr
IMAG0576 by MGRAND3, on Flickr
IMAG0577 by MGRAND3, on Flickr
IMAG0573 by MGRAND3, on Flickr
I am also proud to inform that my rear toe modification on the rtab carriers worked flawlessly.
after my alignment my final specs were
Front: -4 degrees of camber with factory toe. and 5 degrees of caster.
Rear: -5 degrees of camber with factory toe.
its a relief to have the toe on point, as i **** the bowed in look that many e36s get when they run alot of camber.
I am installing my clutch this week. and preparing the car to go to the body shop soon. I also registered for offset kings Irwindale so i have a lot of small details i want to address, mostly in the interior.
Instagram: MGRAND3
thanks man. its been al long time coming, I think I'm finally happy with how my car sitsOriginally posted by Staggered View Postlooks great dude.
Instagram: MGRAND3
