Nice buy for $800! I always love your projects. I'm sure this will be sick no matter what you decide to do to it... But I'm always so shocked by how high these are stock... Stanceworks is making me lose grip with ride-hight reality
Originally posted by BigBody
If it doesn't look good low, it was ugly as shit in the first place.
I agree, the exhaust is leaving, it was the P.O that did that anyway, i am going to save for the exhaust as a whole, as in headers, test pipe, muffler, so it may be a while, after all this is a budget build
the VW community is weird. dont try to understand, its like understanding africa.
So it was running really bad, it was just sitting, and i got a shitty picture, of it sitting, barely running, lol
What the problem was it sounded like a cam lop, but performed horribly, i was thinking it could be the ecu, it could be the plugs, it may still have some bad gas, maybe water in the gas, i wasnt sure, so i did the most simple stuff to see if it worked, i changed the oil and filter (just for maintenance not to fix the problem lol) then i bought some "performance" bosch plus 4 plugs, and replaced them,
plugs :afro
plug caps
this stuff
gumout, i actually didnt use this yet, i am going to fill up the car with premium and put this in, for now i used the stuff that chevron makes, with techron and stuff, it worked very well on the bus, and i hope to see the same results in this car,
bought this to do the dash, but im just going to buy a cover for it, ill use the bondo for when i remove the rear spoiler i guess.
this for touch up
took it for a test drive, yeah it runs better
o nothing really happening lately, minus fixing dyeing the door cards, and saving for some performance stuff to do, here is a pic of the door cards.
and this little beauty i picked up from a friend.
I plan on doing some paint work (wet sanding clear off), and draining the gas tank ,fuel filter because i think there is Trash in the gas, it runs fine at first, then it starts to run bad, and it cuts off, once it sits, it is fine. I thought it was a over-heating issue at first, but everything in that area seems ok,
So, *I'm tired of my car looking bone stock, so i went out side, and cleaned its up some to start, *then i sprayed the wheels with purple power to get all the grime loose, *and then i had to play the waiting game until it dried, *but anyway in to pics. *
I started covering up everything.
first wheel painted, *and the rear being taped up. *
all for painted. *
ohh, and uhh i blacked out the chrome. *
