looks soo good now, cant wait to see more progress
Minty 1969 510 Sedan
Hahaha theres a familiar face... whats happening Indy? Figured I should see what all the hype is about here; seems like a lot of traffic.
Edit: and unless I magically pick up an E9, I dont think Ill ever own a BMW.Last edited by tristinGrind; 06-20-2012, 01:12 PM.
It would be pretty hard to fit a straight six under that hood... V6 no problem, but not a straight six.Originally posted by 244Brick View PostDatsun will always have a soft spot in my heart. You should swap the L28et in it
Well, rummaging through my stuff I remembered that I bought a steering wheel for it, but have no hub to mount it. So now its just a gorgeous paperweight right now. I wish I could scrounge together the cash to pick up a hub, but the funds arent there right now. Ive been thinking of making my own hub at work for a quick fix until I can buy a better one.
That might be a weekend project for tomorrow.
Thanks mate!
Also, while on lunch break the other day, I did a quick doodle of what Im looking for in my engine bay:
Im thinking of removing the two center headlights to provide airflow. The drivers headlight will flow straight into my carbs, while the passengers will flow into an RX7 oil cooler I already have. I will mount it vertically and cover it in a shroud to help direct cold air directly through it. If you look at the sketch, the orange highlighter represents the shroud(s) Im looking to fabricate. It will go along the top of the radiator support, along the sides of the radiator, and cover the oil cooler. That should direct flow straight through my radiator and oil cooler to provide adequate cooling on both fluids.
Tomorrow I will go take some measurements to see what its going to take to make a shroud work. I wont be able to complete a final piece until I pick up a new radiator, but I should be able to make a decent run at it with dimensions from the companies website.
Thanks!
I actually have a line on a set thats even better (read: larger, dishier, rarer). Its going to take some work to fit them though... Im going to need to drop the car even more, cut my fenders, and fit some flares. Other than being expensive, its pretty easy.
My biggest issue is that the rear fender wells are part of how the rear door shuts and seals. So I might need to forgo the use of my rear doors and just keep them sealed the whole time. Im going to have to cut the fender, wheel well, and door itself. Then install the flare over the door seam and slice it to allow the door to open (or at least look like it will open).
