Atom's 2 door Amazon wagon Project:Headquarters
This morning/evening I got the door, fender and door jamb all cut in on the passenger side. I also got the driver’s fender and door off the car and re-installed the lower hatch. I blasted and powder coated some hardware and found out that my upper hatch latch is bad. So is the extra one I got. Working on the fix. Also replacing all the hardware with stainless. I know that’s a dump of info, but it’s late, I just got home and I want to get a few hours of sleep in before I start all over again.
Fixed the hatch latch. Made a new piece from Delrin. Also put the passenger door and fender back on and sourced some more stainless hardware
A little tip for something I do. Align all the parts before hand. With the seals out. Then drill some 1/8 holes between multiple layers. Be conscious of where you put the holes if they’ll be exposed. Then, when you reassemble you can use pick tools, un-popped pop rivers or 1/8” drill rod to align the panels when you re-install.
Once the bolts are tight, pull out the pins and put a dab of silicone/urethane in and over the holes
I’ll try to post more pics later tonight, but I’m reassembling some parts and finally get to see the color in the sun. I love it. It’s hard to photo, but it gets a bit brighter when the sun hits it and a bit warmer in the shade. Bead blasted all the latch components, lubed them up and replaced all the hardware with stainless
Thanks! Hopefully I can make it all function the way I want.Originally posted by Fruttolo View PostDude that hood hinge system is a work of art
I’m so tired guys. I can’t keep up with notifications and I forget the GoPro some days. Paint is going on this weekend. Might be in a booth, might be in a garage, might be in my driveway, but it’s getting painted. There’s some more videos up on my YouTube channel. Same lame stuff. Can’t wait to post up some driving videos.
