Got done more stuff done yesterday. Little things, but important things.
-new front cam seals
-rear cam plug
-iPd solid cam drive pins
-got the cam carrier and valve cover completely torqued down
-got lower timing cover on
-got timing belt on for final time
-located distributor drive w/Yoshifab CAS adapter so it's in the right position
-drilled the block for turbo oil drain
Radiator and oil pump got dropped off at NIW for modifications. I'll get there little by little.
Adam
-rear cam plug
Adam
