'73 mercedes 280, gas, blue.
  • Lookin good! You get your subframe bushing kits off eBay? Currently browsing for new ones for mine...
    • Nice!! I'll be needing this pic soon Do you think its ok to make the brackets from mild steel instead of Aluminium section? Its easier to weld and so on but I don't want it to damage the tops of the bags
      Check out my Alfa restoration here:
      https://www.youtube.com/channel/UC8l...7WzTiNj8Xy6C4A
      • Originally posted by Zman86 View Post
        I was going back and forth on either getting the febi or the meyle ones...i think i'm just going to get the febi ones because they are cheaper.
        yeah totally. i made mine out of al because it's very easy to drill and didn't have to paint afterwards. the re bags have stainless steel end caps, not sure what you mean about the damage.
        build thread?
        • I thought the plates were aluminium too....
          • Originally posted by A4crn View Post
            it looks like your right about them being aluminium, i have cut a ripped bag apart before, those end plates are super thick and very solid. i'll try to find a picture
            build thread?
            • holy crap that bag setup is amazing
              IG: @supseb
              Porsche 911 (996)
              Mercedes-Benz w115 240D
              • looks good... so shiny its almost impossible to see whats going on even with the tape... definately keen for any more shots of the frame mods
                W114 moocedes W115
                • drool. so low classic and clean.
                  very nice
                  • Originally posted by Ducaud View Post
                    thanks man
                    see below
                    very nice
                    thanks
                    ok, size 4 letter size time, i took pictures:
                    this is a subframe:
                    it now has an enlarged area on the spring pocket, it is now flat between the lca rear mounts, and it is boxed on the foward lca mount area
                    it's going to be sweet, you'll see.
                    a tie rod (which i should have got two of), motor mounts (which i didn't get hardware for yet) and a rear diff mount because the old one was fucked. before the wheels go back on the ground i'm going to replace the axles.
                    build thread?
                    • things happening:
                      i trimmed the subframe mounts 7mms, ta-da:
                      boom subframe in:
                      the engine is bolted to new mounts:
                      i'm thinking about polishing that valve cover, and using a smaller round air cleaner on top of my new carburetor, but seriously everything in the engine bay is covered in horse seamen...anyways, the new mounts are like an 1" taller then the worn out ones so the fan is stuck against the shroud. first i was thinking, electric fan, then i was thinking just cut the shroud out, then i was thinking about making a new shroud out of a small sheet of aluminum. now i'm just thinking about horse seamen, that's how i feel about 40 years of what just might as well be horse seamen everywhere.
                      my fender now has a cute little bulge now, i like it.:
                      UNLOP:
                      update over.
                      milk and cookies.
                      build thread?
                      • Couldn't you just raise the radiator a half inch?
                        52 Ford f1
                        62 Pontiac Bonneville
                        69 300SEL6.3 x 2
                        • Nice update...a local mechanic said he has a subframe for sale, I'm gonna jump on it and do some mods Is it hard to remove for the car?
                          • Originally posted by V8Finny View Post
                            i didn't even think about doing that.
                            thanks, i was looking on ebay for a spare subframe but they were all over $500 so i didn't get one. removal is the 2 motor mounts, 4 bolts to the body, control arms, and little stuff like the shocks and motor stablizer. pretty easy to unbolt.
                            build thread?
                            • I just **** it when things are covered in horse seamen.
                              • Originally posted by SheaMoose View Post
                                no h.ate around here.
                                anyways...looks like i should be able to tuck the whole valve stem
                                a big difference from the old amount of lowness in the front:
                                mostly due to this:
                                you can see in that picture that the bag is mounted one inch higher then previously:
                                also new shocks came they were about an inch and a half too long, after slotting the lower mount i'm still 3/4" too long:
                                starting working on shorting the shock going to make it an inch shorter:
                                then the baby woke up.
                                build thread?
