its hte last fucking two pages
V8 miata + exocet = fun
prolly doing these wheels also
Luxury abstract Madors in a 16x9 step lip -20 or so offsetDisclaimer:
I am rude, opinionated, and sometimes come off as a dick. I am just speaking my mind. If it offends you, PM me. Don't go whine to someone else. I am civil, talk to me, just dont be stupid.
and USE THE SEARCH BUTTON
Ok. did some work today!
stripping the miata by Flsimages, on Flickr
aero! by Flsimages, on Flickr
stripping miata by Flsimages, on Flickr
Wiring harness is out. engine is disconnected and all that jazz. Just have to drain the transmission and coolant so i can pull the radiator and driveshaft. at that point, i can pull the body off so we are right on the plan to pull the body by sunday
also fitted some parts. Test fit the brake master, and fully fitted the clutch pedal and master cylinder (note, it is different than yours, i have mine powering a hydraulic conversion on a ford t-5 transmission)
fitment issue by Flsimages, on Flickr
dodgy fitment of clutch pedal. had to open all the holes up, including the main one (main one was due to diameter of the clutch master)
clutch master mounting by Flsimages, on Flickr
Clutch master mounting by Flsimages, on Flickr
still have to lop off the extra threads.
other than that, pretty mild day. most of it was spent running around getting some supplies, and unloading the trailer with tons of stuff, so i only did about 5 hours of work total id say. by lunchtime tomorrow the body should be off chassisDisclaimer:
So update.
Last Import-2 by Flsimages, on Flickr
Last Import-1 by Flsimages, on Flickr
Last Import-3 by Flsimages, on Flickr
Last Import-4 by Flsimages, on Flickr
Last Import-5 by Flsimages, on Flickr
Last Import-7 by Flsimages, on Flickr
Last Import-8 by Flsimages, on Flickr
Last Import-9 by Flsimages, on Flickr
Last Import-10 by Flsimages, on Flickr
Last Import-11 by Flsimages, on Flickr
Last Import-12 by Flsimages, on Flickr
Last Import-13 by Flsimages, on Flickr
Last Import-14 by Flsimages, on FlickrDisclaimer:
and a lil more work before i was done. stripped the subframe. found a bent LCA to knuckle bolt on both sides.
Last Import-0 by Flsimages, on Flickr
getting bushings pressed out tomorrow
and doneDisclaimer:
got more stuffs done
subframe is totally stripped and going ot Powdercoater in the morning for a nice bright color.
Frame is now in the garage, and the engine/subframe are installed. trans mount is mocked up so i can build out the trans tunnel. getting some welding gas tomorrow, so life will be easier
Last Import-6 by Flsimages, on Flickr
Last Import-0 by Flsimages, on FlickrDisclaimer:
and more
Last Import-3 by Flsimages, on FlickrDisclaimer:
that exhaust setup is badass!sigpic
Holy fuck, i had no idea this kind of thing existed. i seriously want to do this.
Subscribed.
