Before I can go any further with mounting the headlights I need to get the radiator in place so I picked up some original metro radiator grommets.
After a bit of tinkering laid out the net for the top mounts on some 1MM steel.
Folded, welded and rubbed down with scotch bright.
The top mounts will sit bellow the slam panel and be plug welded on.
I also started the pattern for the lower mounts. The piece with the grommet will fit onto the radiator and bolt to another section welded to the front panel.
