Saving a Porsche. Vr6 Turbo power
  • Awesome! Can't wait to see the final
    • engine cradle built. huge thanks to my buddy Brandon for bustin ass and finishing the cradle to get it ready for paint. oil pan sits above the suspension bar so im super stoked about that
      If you're ordering custom adapters, call 775.530.2483 to make sure you are getting exactly what you want. Thanks
      follow on IG: eurotrashapparel
      • This is going to be turbo right? Air to water?
        • Following.
          1981 300TD 4 speed
          2000 BMW M5
          Mike Finnelly
          , on Flickr
          IG @michaelfinnelly
          • Originally posted by roof_rack View Post
            yes. not sure what set up im doing but it will be either in the wing or a pair of duals. im just going to get it running NA to start with and build a motor for boost on the side.
            • ok so i got the shift linkage hooked up and shifting perfectly. need one last special bolt to tighten it all down and thats good to go.
              starter also came in. heavy duty bosch
              • Keep the updates coming! Can't wait to see it drive!
                • This is great thus far
                  29 Model A // 55 GMC 100 // 66 C10 // 72 BMW 2002 2.7 M20 Turbo // 75 CB500T Custom // 84 Jetta Diesel
                  72 BMW 2002 2.7 M20 Turbo Build Thread // INSTAGRAM
                  • Amazing work!
                    NathanHeeney.com
                    • Went through the pages, sub'd for more awesomeness !!
                      • trunk seam sealed and bedlined
                        • Love the idea of doing something different... Sub'd to follow
                          • This is fucking awesome.
                            ig: @jonnie86
                            • ok so complete with the bedliner. ran the coolant hoses from front to back. by far the most complex area of this build is the coolant system. i wont go into to much detail, just laugh when the next guy tries this swap and asks...wtf did you do?" haha. also got some banjo ends with hose to loop the rack to make it manual. im still going to run a push pull reservoir to keep the rack full of fluid.
                              • found and ordered 1.25" aluminum mandrel bends to make the hard lines for the cooling system. also grabbed a 4" aluminum square stock and making a home brew intake manifold.
