Ok back on this. Finally lined up a truck and trailer and moved the car back from my buddies who did up all the fab work. sending the cradle and a few other things to powder coat. Will get some updated pics up soon :thumbup:
Saving a Porsche. Vr6 Turbo power
Cant wait to see more progress. This is epic!!!Hit me up for all your quality used bmw parts needs! http://properperformance.com/ IG: Lowlygent
Home brew intake manifold all done up.
What we've come up with for one spot on the coolant system to replace the t stat housing. This is going to upper radiator. uses a standard chevy thermostat
If you're ordering custom adapters, call 775.530.2483 to make sure you are getting exactly what you want. Thanks
follow on IG: eurotrashapparel
So i finally got around to the gas door. As you can see in the first pic it wasn't even close to fitting up in there. So after some debate i just cut everything off. I still had to grind away on the door housing. Fiberglass fenders seemed to be a good a idea at one point so once its up and its running and cooling properly i'll search for metal fenders.
Cut away the tabs
Much better. Still need to dremel around it to make it uniform but it'll do.
Last edited by bradp@adaptecspeedware; 01-12-2013, 04:41 PM.If you're ordering custom adapters, call 775.530.2483 to make sure you are getting exactly what you want. Thanks
Throttle body and ecu just got here. Now i need to order turbo and piping and get that routed up. Sending ecu off to C2 Motorsports
Also got a few bits for interior as well as the rest of the seals i needed
