16x9 -38?
aeion's Nissan Hardbody | Low and Silly
When in doubt, cut it out...
Me too. It's going to require Pathfinder/4wd flares but it should work out well.Find me on Instagram - alex_garagezeroeight
1931 Ford Model A project - http://forums.nasioc.com/forums/show....php?t=2362912
I'd send you mine I cut them up hahaOriginally posted by aeion View PostMe too. It's going to require Pathfinder/4wd flares but it should work out well.When in doubt, cut it out...
Not quite that bad haha. There's no way that a 2wd hardbody would ever hold those without crazy mods. However, that's not terribly far off.Originally posted by TheCrabMaster View Post16x9 -38?
I could still work with them.Originally posted by TheCrabMaster View PostI'd send you mine I cut them up hahaFind me on Instagram - alex_garagezeroeight
I know if I ever step up to the 15x10 for the rear there -44 so much work is gonna have to happen to fit em hahaWhen in doubt, cut it out...
Damn haha. You'll have to get pretty creative.Find me on Instagram - alex_garagezeroeight
I took an Instagram video of my ricebox. Here.
Haha thanks guys. I totally agree about the wheels. The only reason that I have these is because I needed something other than stock wheels to stop the rubbing. Work is looking up so keep an eye out for some updates soon.
Sent from my GT-I9100 using Tapatalk 2Find me on Instagram - alex_garagezeroeight
Alright folks here's a quick update on the small stuff that I've been doing to the truck.
Firstly, I modded the intake a little by taking off the top of the airbox and the snorkel leaving only the filter and the bottom of the airbox, attached to each other via wingnuts. This provides a much better sound and a very surprising increase in torque.
I repainted my horns in white. Much better than they were.
The time came that the Pinto shocks needed replacing. They were absolutely beyond blown and the big rubber bump stop was torn in half on one of the shocks. I ended up doing even more research and found out that 4wd front Hardbody shocks actually compress more than the 2wd ones. Then did more research at work and found out that the KYB GR-2 models compress shorter than the Monroe OESpectrum shocks that we also offer. I ended up getting the GR-2's and installed them one night with good friends and beer. The ride is SO much better. No more bounciness and quite a bit stiffer.
I bought an Energy Suspension poly leaf spring bushing kit a couple weeks ago and if all goes well those will be installed this weekend. This should be a major improvement as my current ones are stock, rubber, and falling apart enough to cause some rear alignment issues for me. Plus they squeak like crazy and that's not cool.
The other day my battery was dead when I tried to go to lunch. That was annoying because I had to pay money for a new one. Always lame.
Future plans before I go ahead on the wheels include new ball joints, tie rods, sway links, and possibly spindles.
Stay tuned.
Yeah there is such a noticeable feel in throttle response just from taking the cover off the intake! An dis so much louder hahaWhen in doubt, cut it out...
Throwback something. I need to go see this thing again.
