'03 350Z Twin Turbo Built VQ Build
  • '03 350Z Twin Turbo Built VQ Build
    Figured I'd help PowerFab out and share (whore) my engine build they are doing for me. Little background for those that don't know... Oct '05 traded in my '03 Evo 8 for my current '03 350Z Touring 6sp. April '08 added the JWT 700BB (GT28RS) Twin Turbo kit among other mods. About a year after that regretted not building the block and talked about doing it for years! 31-Dec-11 It was loaded up and towed to PowerFab where an Import Parts Pro Stage 3 long block and other mods is being installed. Should net around 550-575whp+ on pump. See below...
    Current Set-up:
    Vehicle: 2003 Nissan 350Z Touring 6sp
    Engine Code: VQ35DE
    ECU: TurboXS UTEC
    Audio & Electronics:
    - Bel RX65 Laser/Radar Detector
    - Boyo VTL300 Rear Camera
    - Clifford Matrix 12.5 Security Alarm
    - Defi-Link 60mm BF Series Boost Gauge & Fuel Pressure Gauge
    - Defi-Link Control Unit, Display & Indicator II
    - JL Audio 500/5 Amp
    - JL Audio 10W3v3 Sub
    - JL Audio C5-650 Components
    - JL Audio TR650Cxi Rear Speakers
    - Nismo Horns
    - Optima Yellow Top
    - Pioneer AVIC-D3X DVD/Nav Receiver w/ XM SAT Nav
    - TurboXS DTEC Map & Tuner Wideband
    - TurboXS UTEC w/ Map Switch
    - Wicked CAS 350Z Corner Box
    Brakes & Suspension:
    - Aerosync CF Strut Tower Brace
    - GTSpec Fender Braces, Front Tie Brace, Rear Lateral Arm & Rear Tie Brace
    - Hotchkis Stage 1 TVS Kit
    - PFC1038 Front Pads
    - Posi Quiet Rear Pads
    - SPL Endlinks (F&R)
    - StopTech Big Brake Kit (14" 4-Pot Front, 13" 2-Pot Rear)
    Engine & Drivetrain:
    - AP Stainless Steel Clutch Line
    - ARC Oil & Raditor Cap
    - ARC V2 Oil Catch Can
    - AutoTechnic CF Shroud
    - Gallery Belmount Blue Dress Up Kit
    - JWT Clutch & Flywheel
    - JWT Oil Pan Spacer
    - NGK Iridium IX 1-Step Colder Spark Plugs
    - Project Kics Magnetic Oil Plug
    - RC 750cc Injectors
    - Stillen CF Battery & Brake Fluid Covers
    - Stillen CF Engine Cover
    - Stillen Oil Cooler
    - UR Underdrive Crank Pulley
    - Walbro 255lph Fuel Pump
    Forced Induction:
    - HKS SSQV BOV
    - JWT 700BB Twin Turbo System
    - Perrin Boost Solenoid
    - Swaintech BBE Coated FMIC
    Intake & Exhaust:
    - APS 2.5" Test Pipes
    - Cosworth Intake Plenum (Polished)
    - Stillen True-Dual Cat-Back Exhaust
    Interior & Exterior:
    - Aerosync N-Style Front Bumper
    - AUT Carbon Fiber Z Emblem Filler
    - CraftSquare TC-N1 Mirrors
    - Dual Guage Pod A-Pillar
    - JDM Fairlady Z Emblem & Smoked Markers
    - Nismo Sides
    - Nismo Ti Shift Knob
    - '06 OEM LED Taillights
    - Perrin Shorty Antenna
    - Rear Strut Brace Carbon Fiber Cover
    - Removed Rear Wiper
    - Seibon TS-Style Carbon Fiber Hood
    - Seibon TT-Style Carbon Fiber Rear Lip (Custom Painted)
    - Shift Style Custom Shift Boot
    - TEIN Hood Damper
    - 15% Tint
    - TiTek Dry CF Air Duct
    - Varis CF B-Pillars
    Wheels & Tires:
    - ARP Wheel Studs (15mm longer)
    - Ichiba Wheel Spacers (5mm Front)
    - Project Kics NeoChrome R40 Racing Lugs w/ Locks
    - Work Meister S1 3-Peice (19x9.5 & 19x11)
    - BF Goodrich KDW Tires (255/35-19 & 285/35-19)
    Last Dyno:
    2012 Build:
    IPP Custom Stage 3 Long Block:
    ~~ Cosworth Rods, CP 8.5:1 Pistons w/ Ceramic/Moly coating on the piston tops & skirts
    ~~ ACL Trust Washers, Main & Rod Bearings
    ~~ ARP Main Studs & Rod Bolts, L19 Head Studs
    ~~ ATI Street Damper Crank Pulley
    ~~ Heads Redecked, Ported Intake/Exhaust Runners, 5-Angle Radius Cut Valve Job
    ~~ JWT C2 {261* w/ .456 (11.58mm) lift Intake & Exhaust} Cams
    ~~ JWT Heavy Duty Springs & Shims
    ~~ Viton Valve Seals
    ~~ OEM Gasket kit with Cometic Head gaskets
    ~~ OEM VQ35 "Rev-Up" Oil Pump
    ~~ OEM VQ35 Pathfinder Rear Cooling By-Pass
    ~~ Nismo Low Temp Thermostat
    ~~ Z Speed Performance Aluminum Undershroud
    Fuel:
    ~CJM Stage 2 Return Fuel System w/ Blue Billet Fuel Rails
    ~~ Aeromotive 340lph In-Tank Fuel Pump
    ~~ Injector Dynamics 1000cc Injectors
    EMS:
    ~ HalTech Plug-In Pro ECU Replacement EMS
    ~~ HalTech Boost Control Solenoid
    ~~ HalTech Dual Wideband Kit w/ 2 Sensors
    ~~ Dual Wideband Gauge
    Drivetrain:
    ~ Nissan CD009 (2004+) 6sp Transmission
    ~~ Carbonetic Twin Disc Carbon Clutch w/ Carbon/Steel Flywheel
    ~~ Quaife Helical LSD
    ~~ SPL Solid Diff Bushings
    Exhaust:
    ~ Greddy RS Cat-Back Exhaust
    ~ PowerFab 3" PolyDyn Coated Downpipes
    ~ PolyDyn Coated Manifolds & Turbine Housings
    Suspension:
    ~ Tein Comfort Sport Coilovers w/ EDFC
    Wheels & Tires:
    ~ HRE P43SC in Satin Black
    ~~ 19x9.5 +20 & 19x11 +25
    ~ Toyo R888 (Still Researching)
    ~~ 265/30-19 & 305/30-19
    Pics:
    ‎"I don't want to build street cars. Manufactures build street cars. I want to build race cars!" ~Robert_K
