This thing is so rad!
JDM/USDM/GDM inspired E36 Compact from Uk
Gave the top a quick polish with Zeppelin (use it on the wheels)
Had to move the temp sensor as it used to sit on the right rad hose. Use some alloy pipe to extended the hose. Drilled and tapped a hole for the sensor in the thermostat housing now, you can barely see it. Cable tied the top of the rad for now haha
yessssss
No leaks woo! works reaaaaaaaaally well compared to stock, and a lot easier to bleed. Fill it up and go!
