Few more photos, boring but look kinda cool.
I made some inroads yesterday to completing this. But yet again tiny setbacks costing me time.
Marked out the supplied top mounts for cutting down to size.
Eating my way through cutting discs, chopped down the the top mounts roughly. You don't see them anyway.
Took a flap wheel to the edges to smooth it off somewhat.
Work out where the holes needed to be, from where I thought they should be. Terrible mistake on my part. Wiggle around a drill bit until its right.
Using a socket and a vice, due to the lack of a press, force the studs into place.
Complete, odd, mishapen top mounts. That don't fit perfectly, and the studs probably did need pressing as half came loose. Leaving me in a very tough situation with regards to trying to fit them....
Fronts are on, need to do the airlines, and put caliper back on as well as tighten all the bolts. I haven't done the ARB droplink yet. That can wait. I'm getting impatient.
Rears are a cunt. Plain and simple. No room above the mount to get your hand, one side top mount is fitted and tried to fit the strut to that, failing, otherside, strut is fitted to top mount, top mount goes to be fitted, two studs come loose. One stud is holding it in place at the moment whilst the others just spin.
Also the holes for the airlines were like 2mm too high. I need to learn the whole measure twice cut once thing. So thats an arse ache of filing to get it lower down.
All in all, progress, yet slow. Fingers crossed today.
