Hell yeah, nice clean base you have there.
98 Civic ex (Project lowfodo)
Thank you sir, the pictures make it look a lot nicer than it is. It has little dents all over the place that just drive me crazy.Originally posted by hi its me alec View PostHell yeah, nice clean base you have there.
Working on the trunk setup today ran out of time and my first time trying to bend pip ended up with straight pipe and a broken pipe bender. So we are just going to run pvc air line lol.
Two tanks, one 3 gallon and one 8 gallon with 8 valves for front back side to side on a 10 switch box. This isn't some litttle 1/4 air hose I'm running 3/8 hose and valves on 200psi.
compressor is mounted behind the big tank and the valves are under the floor. It's not the prettiest and could still use some cleaning up but this is what I'm at so far. Will finish it up and throw it in tomorrow. In total I have 11 ports two will be used to transfer air between the tanks one is the pressure switch two go to the valve manifolds two will be blocked off and one has a t for the compressor in and a air fitting so I can connect impacts and air tools to it incase of emergency.
Still working out some kinks and need to figure out my air leaks. I'm still running my 120psi switch till the 200psi comes in. I drain 11 gallons of air sitting at night. Need to go over all my fittings. I think it's leaking at the air line that connects to the rear valve manifold. Thinking about sanding down the black paint and painting the tanks a different color and maybe some led lighting to show it off when I have the trunk popped.
