So here it is, the build thread on my car. It's a 99 SVT Contour. It will be a slow process because working a not so baller paying job and college really takes away the time and money I'd like to put into the car. Anyways, like I said, it will be a slow build and I may not update this very often except to post new pictures. On with some details and pictures.
Drivetrain:
2005 full 3 liter Taurus/Sable motor swap
Untuned at 192 whp and 194 wtq
EGR delete
GCK Axles
Suspension/brakes/wheels:
KSport coilovers
Subframe connectors
BAT rear strut tower bar
BAT 21 mm rear sway bar
OMP front strut tower bar
Custom rear adjustable tubular toe arms
17x7 et 40 Konig Imagines
Exhuast/Intake:
Open element short ghey-ram intake
Gutted manifolds
Sho Shop y pipe with catalytic converter delete
Removed resonator into stock catback
Plans for the future:
- 20mm spacers all around to flush these rims out
- Camber arms for the back
- Run at least a 17x8 rim. (9J if I can find the right offset)
- Build another hybrid high compression NA motor to swap in
- Misc plans such as bigger brakes, redo interior, and other things
Stock when I first got it
My quick messy engine shot of the swap
Static height daily driven after the many times messing with the ride height
Update: Night time photos
And these last two pictures are my favorite.
Drivetrain:
EGR delete
GCK Axles
KSport coilovers
Subframe connectors
Exhuast/Intake:
Gutted manifolds
