Pretty
Codename: Arial Blau
The LocTite was terrible. This was amazing:Originally posted by 244Brick View Post
Which one do you prefer? I had 3m 77 and it came apart in the heat!
IG:uvebeenrobd
Delayed update. With the mad sprint to get the car all buttoned up for WekFest I haven't updated in a good minute:
Got all the powder-coated & polished pieces back under the hood but chasing down a bad crank sensor presented many issues. No pics of the finished install thought...sorry.
Shaved 5MM off the backpad of the HREs so that I could 'back it up & dump it" without scraping up the lips or having to pull fenders:
Front door cards installed:
Rear door cards installed:
Trunk complete:
Rear complete:
Fronts complete:
Brakes bled, wheels polished & mounted:
End result:
IG:uvebeenrobd
love this!Hit me up for all your quality used bmw parts needs! http://properperformance.com/ IG: Lowlygent
Testing fitting some new wheels:
Front at ride height with 20mm spacer:
Front at 1/2 ride height with 20mm spacer:
Rear at 1/2 ride height with 20mm spacer:
IG:uvebeenrobd
I'm not 100 percent on these yet. I have to run a 20mm spacer to clear the bags in the front and the low offset of these wheel is presenting some backside clearance issues. I'm going to try moving to a sleeve style bag in front to see if that will resolve the clearance concerns but only as long as it doesn't sacrifice my ride quality.IG:uvebeenrobd
