Ok I was going to wait until I could post more pictures, buuut. I got the second strut top built and installed and started making space in the inner fender area for more low. I'm having something of an air leakage problem. I have checked all of my fittings and they seem air tight, so I'm a bit worried it may be an internal problem with the bag. This is my first time using a bag strut, How much if any leak down is normal? I've started work on the rear bags as well, however fords "don't f**k with me" engineering mentality is going to make that more difficult than anticipated. The spring is held with just the spring pressure and two little rubber biscuits. As soon as I air down the bag it has the potential to slip out of place if I mount it in the factory fashion. Any way I have some engineering to do. once I get the rears rapped up I'm going to pull the rear bumper for step pad, and marker light removal, as well as exaust notches. Also what are you bag folks using in the way of strut bearings? As soon as I have a non cellphone internet connection I'll post up some more pictures.
A taurus wagon? Really?
 I totally want to ride in that rear seat and drop m&ms on your subwoofer and have them bounce into my mouth.
 “Producing something of quality is obsessing over details nobody sees.”Originally posted by Longboarding_Gyou sir, win this battle.
 This is the most amazing thing I have ever heard ever.Originally posted by Krank View PostI totally want to ride in that rear seat and drop m&ms on your subwoofer and have them bounce into my mouth.
 As much as this car sucks 99.9% of the time is as much as this .1% is awesome.
 Follow Me On Instagram! @jvc8790 #jvcphotography
 I bolted my airbag mounting brackets on top (the side with the valve) and the bag's metal end directly to the bottom of my spring seat. Typically, people say to tack weld the brackets to the spring perch, but it won't just sit there under pressure like a spring - top and bottom need to be fixed to the car.Originally posted by Fuzzy Bunny View PostOk I was going to wait until I could post more pictures, buuut. I got the second strut top built and installed and started making space in the inner fender area for more low. I'm having something of an air leakage problem. I have checked all of my fittings and they seem air tight, so I'm a bit worried it may be an internal problem with the bag. This is my first time using a bag strut, How much if any leak down is normal? I've started work on the rear bags as well, however fords "don't f**k with me" engineering mentality is going to make that more difficult than anticipated. The spring is held with just the spring pressure and two little rubber biscuits. As soon as I air down the bag it has the potential to slip out of place if I mount it in the factory fashion. Any way I have some engineering to do. once I get the rears rapped up I'm going to pull the rear bumper for step pad, and marker light removal, as well as exaust notches. Also what are you bag folks using in the way of strut bearings? As soon as I have a non cellphone internet connection I'll post up some more pictures.
 Edit: As for leak down, I think the bag-over-strut design has a tendency to leak a little, but if your struts have quick connect fittings, those things leak like hell when you turn the car. If so, I would swap them to normal compression fittings.Last edited by exexpat; 11-15-2011, 02:00 AM. My first JDM project after decades of European cars! My first JDM project after decades of European cars!
 This is really great man. I was surprised how well the front turned out and now I'm dying to see what happens to the rear!
