Sub'd! I've got a wagon fetish..
Bagging my 07 Impreza 2.5i Wagon
Thanks everyone! It's goin along real well! For the picture hungry, I hope this post will satisfy
Day 4 - Plumbing.
Here's how the tank looks all fitted up, that elbow on bottom there will be the drain, and the tool port will be on the right side when looking down at the management from the back of the vehicle.
The water trap proved to be a bit of a challenge, after debating the idea of fabricating a mount or possibly using hard line, this crazy chain of fittings ended up working out perfectly... not a single leak! It's much more solid than hard line (of course), with a couple more leak points but overall, I'm happy with it. I can fit my hand down there and I'm considering setting up some sort of a funnel system to easily drain the water trap out through an OEM gromet.
Here's the final positioning of the tank before bolting it down, with room for fittings and ports and such. Drilling holes was a bit of a pain, but I got it done.
The drain line runs underneath the tank...
...and comes out of this OEM Gromet! (p.s. I have stiff black kartboy hangers coming in the mail to replace those wobbly OEM exhaust hangers)
After a lot of measuring I bolted down the tank and ran the air lines from the tank to the manifold and from the water trap to the tank. The fittings on the water trap side do line up well, but I made the mistake of bolting down the tank before getting that piece of airline in and couldn't get it to bend enough afterwards. I'll most likely end up fixing this later to make it a bit cleaner. I'm loving Will's idea for the 3D Bag Riders stickers, they look real slick (this photo doesn't do them justice... at all).
A little update up front, I installed a kill switch next to the rocker switch so I don't have to power cycle my car in the event the rocker switch flashes an error code which sometimes happens if the ECU gets confused. It will also be convenient for moving my car or really just any time I don't want the management/compressor to turn itself on when the car turns on. I wired it into the same fuse as the cigar lighter. Additionally, I'm not really a fan of the little black stick on button that comes with the rocker switch, so I replaced it with a little red momentary pushbutton from Radio Shack. Here is a shot of my management zone as of now...
The guys at the tire stretching shop said they might have them done today, so with any luck I'll be back with a shot of how they came out in a few hours
Fingers crossed! The plan for tonight is to hopefully get the front air lines and sensor arm lines run up to the front of the car. I've got plans around 8, but that still leaves a good 3 hours of modding! Results of the evening will be posted tomorrow, and expect a lot of progress to be made this weekend!
Thanks for the support everyone, this is an incredibly fun project and it's coming along very smoothly!- Call us at: 802 . 735 . 2574 - Email us at: sales@bagriders.com - - // - - We're open: Monday - Friday 9:00 - 5:00 Eastern -
Thanks!
Got my wheels back!
I have a question about the drain line from the bottom of the tank. How do you "activate" it? It just looks like a 90* fitting with a line running out. I'm trying to figure out a solution for mine, and yours looks like it might fit the bill. Can you elaborate on this?
I ran the line out through the grommet and put a drain cock on it, but the drain cock was leaking air so I ended up just putting a hex plug on it. When I want to drain out, I just have to unscrew the hex and then re-thread it. Kind of a hassle, but its clean and I shouldn't have to drain my tank very often with a water trap between the compressor and tank. A drain cock really would have been ideal, but I tried a second after the first was leaking and had the same issue. I'll probably drain the tank no more than once every few months, so I'm not too bummed.Originally posted by Fastphil View PostI have a question about the drain line from the bottom of the tank. How do you "activate" it? It just looks like a 90* fitting with a line running out. I'm trying to figure out a solution for mine, and yours looks like it might fit the bill. Can you elaborate on this?
Got a --ton-- of work done this weekend, I'm uploading pictures now and will have a new post up within the hour!- Call us at: 802 . 735 . 2574 - Email us at: sales@bagriders.com - - // - - We're open: Monday - Friday 9:00 - 5:00 Eastern -
Alright, here comes a few posts with what was done this weekend
I'm starting with Friday night, which was only a few hours of mods after work before hitting the town for the evening.
Day 6 - A Few Hours of Air Line
We decided to get the front air lines and sensor arm lines run as those were going to take the longest. I couldn't find a good path underneath the car, so I decided to run both air lines and sensor arm lines through the passenger side paneling. Here I've ripped out some paneling and styrofoam and got one air line and sensor arm line out.
The lines then go under the seat and tuck under the paneling as shown here... There was plenty of room for both air lines and both sensor arm lines, it just took a little cramming
As we were running out of time for the night, we decided to coil up the cables and air line and leave them in the cabin under the passenger side floor mats. Here's Taylor zip-tying everything together temporarily.
With the paneling back in, you can see how everything fit in there nicely, and we left it ready to go through the firewall.
This here OEM grommet will make for a perfect entry point into the engine bay. It is easily accessible from the passenger side just behind the glove compartment.
I decided to use some tubing to cover up my lines and keep things clean. I know I'll have to cut and re-crimp the sensor arm lines for the rear and don't want an ugly mass of electrical tape showing.
With all the paneling back in, everything was back to looking neat and tidy before we called it an evening. We left the shop Friday night very ready for a solid Saturday of modding!
I'll be separating these days into different posts for organizational purposes, so here is Saturday.
Day 7 - Strut Saturday
Finally, the day had come to install the struts. We got to the shop early and got right at the install. Here is a shot of the rear strut sitting on Kevin's table... with Kevin uhh... in the picture....
I picked up these grommets from ACE, they're a perfect size to run both air line and sensor arm line through. Here I was testing out some positioning before drilling holes.
I drilled out the holes for the grommets and slammed them in there, but they were a little on the loose side...
I decided to put some duct tape around the edges to help make a tighter seal. This was then reinforced with some silicone.
Now the grommets sit in there nice and tight, so I ran some air line out for the rears.
Here's what I was talking about with the sensor arm lines. This tubing can house the air line and sensor arm lines.
We didn't have any fittings that threaded into the D2 struts, so we had to use the fittings they came with which were 1/4" airline. We downsized the airline coming out of the manifold in an easy to reach location in case I end up re-running air line at some point.
Meanwhile, the air lines and sensor arm lines came through that grommet in the firewall without a problem. The clips on the sensor arm lines didn't even have to be cut off!
Big thanks to my friend Taylor for coming by and providing an extra set of hands during the install, here he is working away at one of the rear struts.
The rear struts came out without too much hassle, here we are ready for slap in the new air struts!
Here is one strut installed in the rear with airline all connected.
The airline routing in the rear was quick and easy. The sensor arm lines follow the same path.
With the rear done, we moved onto the front. Here's a shot of the OEM strut before we took it out. Kevin has been on the lookout for a winter beater Suby, so we saved my old struts to put in whatever Suby he picks up. They only have about 40k miles on them, which will probably be about 100k less than whatever he ends up buying. Thanks for all the help buddy <3
The front struts had been taken out a couple days before this in order to get a frame notch done, so they came out with ease. Here's one of the new fronts ready to be put in!
A closer shot of that frame notch and a lighter for reference. There is some good potential for low here!
Front struts are in!
The air line downsize happens in the engine bay for the front. Whenever I have to take out my front struts to coil them down or adjust camber or anything I have to snip the air line as it's a compression fitting. This only means cutting off a minuscule amount of airline, but eventually I will run out of slack and have to re-run air line. Having the conversion happen in the engine bay will make my life a whole lot easier - turning a an hour to two hour task into a 30 min task.
With airline connected, we were ready to test out the slamability of the struts.
The fender roller was nowhere to be found and I really didn't want to baseball bat / mallet my fenders, so I decided against putting on my new wheels. Luckily a friend only an hour and a half away had a nice eastwood fender roller so I headed out to roll the fenders. Here is what the car looked like bagged on OEM wheels. You can see Kevin's Suby is hiding behind mind
Saturday was incredibly productive! Without the fenders rolled and new wheels on, we couldn't be sure of the min/max height so we didn't mount the sensor arms. We left that for Sunday, which I'll cover in the next post.- Call us at: 802 . 735 . 2574 - Email us at: sales@bagriders.com - - // - - We're open: Monday - Friday 9:00 - 5:00 Eastern -
Alrighty, this post is gonna be yummy!
Day 8 - Sensor Arm + Stancing Sunday
With the fenders rolled, I immediately slammed my new wheels on and tested out some fitment. Not bad, but needs moar camber!
I bought H&R Camber bolts for the rear (the front has plates and an OEM bolt, the rear has no plates and the bolt doesn't camber nearly enough) which are pretty dope. Unfortunately, the bottom bolt was about 3/4" too long (it was hitting my cv boot) so I lopped off the end of the bolt and about 1.5mm off the spacer. Now the bolts fit with about a credit cards width to spare. The extra camber was well worth the effort
You'll see the results further down the post.
Figuring out a good spot for the sensor arms was a bit tricky. I had already adjusted camber so I really didn't want to take out my struts. This seemingly pointless metal flap was blocking a really nice spot, so I did the only logical solution and cut it a bit then smashed it a lot with a hammer. Here is a shot before I started smashing - I planned on cutting the metal from the right, so I had folded it a little, but then decided smashing would be easier (and funner).
One rear sensor arm DONE! The nut is tack welded to the control arm with a bit of wiggle room even in monster truck mode. Those sensor arms are expensive, so I took my time to ensure I wouldn't max them out.
The driver side was done just like the passenger in the rear... cut, smash, drill, mount, weld!
The sensor arm lines went right along with the rear air lines.
I then cut the extra slack from the wires and crimped everything back together. If you'll be at h2o you may get a chance to see what's so 'top secret'
Put everything back in the tubing, clean!
Here is how the front sensor arm lines are positioned. We put some spacers so the arm won't rub on the ABS line.
I decided to jack up the front wheel as far as it would go, you can see I've still got a lot of potential for slammage! My wheel is hitting on the wheel well, I need to get some tubbing done which I'm hoping can happen before h2o.
Here's how it sits now, I'm pretty happy with it!
A few more shots I took at the shop...
I'm happy with the camber in the back
The driver side...
This morning I took a few shots in the parking lot... The front will go lower as soon as I can get the tubbing done.
I'm hoping to lay frame in the front once the tubbing is done, and I still have some room in the back to tuck some wheel if I cambered the rear a little more, and I should have camber plates for the rear in a couple weeks. I'm undecided at this point, I really like the fitment. Opinions? Here's one last shot
Thanks for all the support everyone! This has been a TON of fun, and I'm quite happy with the results. I should have some pictures taken with a nice camera in the next couple of days (all these pictures were taken with my Droid) and I'll be sure to post them up. I hope everyone had a fantastic weekend - fall is quickly setting in here in VT and the scenery is beautiful. If you'll be at H2O this weekend I'll see you there!
-- John Hall
Thank You...
Bag Riders
Will Fisher
Rali Kepchar
Kevin McGovern (SubieRuby)
Taylor Menezes (tstacks)
Cyrus House
Bret Hudson- Call us at: 802 . 735 . 2574 - Email us at: sales@bagriders.com - - // - - We're open: Monday - Friday 9:00 - 5:00 Eastern -
