my em2, the bastard civic
  • #16
    You have an exceptionally long middle finger
    Cole
    • #17
      OBK's Build Journal
      • #18
        tons of views, no criticism?
        here is some of the old work ive done, suspension is pretty much done with now. nothing else to changed. but here are some photos of the process;
        then this happened
        so banged out the hubs, new extended studs went on
        [IMG][/IMG]
        [IMG][/IMG]
        rsx cloth seats went in
        OBK's Build Journal
        • #19
          ordered 1 meter rod to replace the measly 1.5 inch inch studs that are on the hotchkis camber plates
          go to work early. cut some rod on the ban saw
          this is how long they are;
          mind you, this is what they were when I got them;
          lol kinda crazy, im made them too long, my fault, I'll cut them down once they are inside the car with a cut off wheel. no biggie.
          here it is all welded;
          plug welded on the back side. and welded on the other side;
          and this is how it looked with some larger hex bolts used as spacers;
          again, it wont be that tall. cutting it down much shorter later on.
          the only thing I have left is to drill out a piece that goes on the spring, drilling it to allow the shock shaft to go inside of it, instead of just on top where its thread;
          and, old vs new;
          back to the inverted ends, had to modify them
          instead of drilling out my shock arm for the tie rods. I took them to the lathe to remove the tapered end in the bolt. weakening it slightly, but the bolts will be hardened after modification is complete. (aka, make sure they fit in the shock arm)
          before and afters;
          on the lathe;
          inner tie rods are on with the new bracket.
          old bracket vs new one. very beneficial;
          on the the car;
          I can only get up to knuckle in the middle of your finger under the frame
          went back to my old set up
          OBK's Build Journal
          • #20
            and the current spring set up
            had to modify an inner tie rod to get the alignment squared away
            was filled with weld after i snapped the pick
            OBK's Build Journal
            • #21
              Damn this car looks good. I need to show my friend this thread to give him some inspiration, he just got one of these and it's all riced out.
              | 92 Corolla AE92 | HKS SMF, Testpipe, Hyperco/Tokico/GC | Houston, TX | 86Garage |
              • #22
                and now its painted *dance*
                went to IA 2011
                and the most current photo before I put it on stands;
                OBK's Build Journal
                • #23
                  extended ball joints and new rear camber arms are on. and went about half in the rear lower and a quarter inch in the front.
                  its been on the ground for about two weeks now;
                  OBK's Build Journal
                  • #24
                    Damn dude, this thing is silly low.
                    How does she ride/drive?
                    4 Cars, 0 Cupholders
                    • #25
                      new height is awesome
                      • #26
                        Very tidy, not a huge fan of hondas but damn thats nice
                        • #27
                          I love EM2s. Lovely just lovely
                          2002 Infiniti I35 ( 6 speed swap in progress )
                          2004 Nissan Maxima SE 6 speed ( Closest car to being "stanced" )
                          2003 Nissan Maxima SE 6 Speed
                          2002 Lincoln LS
                          On the verge of being Stanced
                          • #28
                            nice ass and nice car.
                            • #29
                              not a fan of that front lip, doesnt really flow well.
                              but other then that, it looks real good!
                              • #30
                                Awesome idea on raising the camber plates! Props on driving that low in NJ too
                                "This community is made up of people who strive to push the boundaries of the conceivable"
