Bagged Mercedes W115...
  • #76
    sick love the car man!! I am totally jealous
    • #77
      looking good man keep it up, keen to see some more pics
      • #78
        Is the W123 in the background yours as well?
        1981 300TD 4 speed
        2000 BMW M5
        Mike Finnelly
        , on Flickr
        IG @michaelfinnelly
        • #79
          I had a 123 for a couple months that I parted out.
          • #80
            Glad to see this is obviously in great hands.
            • #81
              Received a bunch of stuff I was waiting for from Mercedes yesterday, so the car is now back together and driving. Unfortunatly, I have still not received my driveline parts from Mercedes Source...
              The run-down of whats been done so far
              New shocks all around
              clean/re-seal waterpump and thermostat housing
              new thermostat
              re-cored radiator, upgrade frow two row to three row
              new axles
              new axle seals all new hose clamps in engine bay
              new power steering lines
              new waterpump housing to thermostat housing hose
              new crankcase vent hose
              cooling system flush
              power stering system flush
              A/C delete, still have to remove condensor and wiring, then plug holes in firewall
              replaced injector pump delivery valve seals
              scrubbed the engine bay with a stiff bristle brush and degreaser, then power washed
              new diff oil
              removed front sway-bar since it was not hooked up/cant be used
              Awaitng arrival of new differential mount/hanger bearing kit/driveshaft flex-discs
              I can not believe the difference in how the car drives now with new shocks and axles. No more vibration while driving lowered/aired out, and much less bounciness over dips and bumps. Also like how the engine bay looks without all the A/C crap in the way, and I;m considering re-locating the battery to the trunk since the bay looks much better without it there...
              Rad Before
              Rad after- Thanks to the guys at Hamilton Radiator for doing a great job
              New front shocks, no pictures of the rears. The rears were hard to find because none of the parts stores would look up shocks by the shock part number, only by vehicle application. After going to three different stores, Napa was able to look them up
              Goodies from Mercedes
              Re-assembly
              Test-drive to the car wash
              Engine bay before...
              Engine bay after...
              Next things on the list are replace the driveline components when they arrive, replace the engine mounts/engine shocks (Left side engine mount has disintigrated due to leaking fuel), fix leaky injector pump, have new oil pan modified to allow installation of skidplate. Also, the transmission has started shifting very poorly, I may have to take it out and have it re-built:banghead:
              • #82
                The stuff from Mercedessource.com arrived today. Despite taking three weeks to get here, I'm still happy. The packaging was fantastic, and they even sent me tools, instructions, a pair of nitrile gloves and candy because I ordered close to Halloween.
                New parts- 2 new driveshaft flexdiscs with hardware, driveshaft slipjoint boot, transmission shifter linkage bushings, hanger bearing housing and new bearing, new differential mount.
                Dont know when I'm going to get to work on it again. Trying to store it in my Dads garage, but the 12 motorcycles in there are taking up most of the space, not to mention all the other stuff. I may have to pay to store it elsewhere, which means no working on it over the winter unfortunatly...
                • #83
                  Dope. <3 W115s
                  Originally posted by Longboarding_G
                  you sir, win this battle.
                  “Producing something of quality is obsessing over details nobody sees.”
                  • #84
                    No work getting done lately as I have no place to work on it or store it, so in the driveway it sits...
                    • #85
                      Mercedes source always included candy for my Father and I when we ordered through them.... Just sayin haha
                      Car looks great!
                      1981 300TD 4 speed
                      2000 BMW M5
                      Mike Finnelly
                      , on Flickr
                      IG @michaelfinnelly
                      • #86
                        Originally posted by Zman86 View Post
                        Soooooooo nice, do you have these two shots in a higher res? I'd love to add them to my wallpaper collection
                        • #87
                          ^ Unfortunatly, I do not, as those are the previous owners pictures
                          • #88
                            bowseeeee
                            • #89
                              keep up the good work!looks like a lot of maintenance was needed
                              • #90
                                Love your car!
