Did some more work today. Got the rear bumper off.
Found a small spot of rot.
Finished draining the fuel that was in the tank. Having to remove the fuel cap with channel locks confirmed my suspicion that the inside of the tank is heavily rusted. Tank will be coming out for a cleaning and lining application. In the mean time I put 15 litres of premium in it for moving around the yard.
Then it was onto the interior. I always like to remove the seats and do a thourough cleaning on my old cars, and since it does not have carpets in a typical sense, but rather larger padded form-fitting mats, it's easy to check for rust. I swung my head under the rear seat, and was quite surprised to find $180 in $20's.
Off to a good start!
Pulling everything out took about 25 minutes. I have an earlier style black interior without headrests that will be going in. This one, aside from the driver seat needing a going over, is in quite good shape, I just prefer the older one.
The rustiest part of the car so far. Seems nearly everywhere in these cars leaks water into the interior, this one being no exception. I'm surprised it's not more rotten given the amount of moisture I've found.
Found a couple holes while scraping away, but this has been it. No big deal, very minimal compared to how bad I've seen these things. I'll post up some of the rust I found in the green one later.
All in all it's looking pretty good so far. Fired it up with the new oil and fuel and let it run up to temp. It is a much, much happier car with new fuel in it. The lifters are a little noisy, but the valves have probably not been adjusted in a very long time. A couple were sticking when we first fired it up a couple weeks ago. Only concern so far is that there's a bit of blue smoke from the tail pipe. Hoping it's just from sitting around all these years.
Debating whether to go in tomorrow to scrub the exterior...
Sent from my iPhone using Tapatalk
