As i posted before my rear bumper was damaged by the mot station. 2 months later its finally getting sorted. bumper was cracked in 2 places and all 108 L.E.D's are being replace. Same design as last time but the the very inner line each side will become a fog light to make it legal
in the future i was going to get the front resprayed but as its already at L.A.Paintworks i decided to get it done now. This consists off front bumper, headlights, grill, scuttle panel, wiper arms aswell as all the wholes in the slam panel which wasn't being used smoothed over and painted. Also got my 5 gallon air tank painted white ready for when i get air in a week or 2's time. The rear 1/4 was getting painted to as there was some damage there.
Also as i got a fuel leak and the front end was in bits i decided to get engine degreaser and coat the engine with it then jet wash it down. As this was at the body shop i used there airline to blow all the water sitting in all the little places in the block. as you can see below there was a lot of buildup of fuel/oil there. Least now it makes it a lot easier to find the leak. Im thinking its the high pressure fuel pump or a t piece just above it although not 100% yet.
heres 2 rolling shots when we were convoying to HOW - Belgium 2010
Heres a few photos from there.
straight away i thought head gasket. I filled the rad up with water to see if it was leaking from anywhere else and it all seamed fine but after the engine was on for about 30min it started to overflow again. ill get back to the show in a bit but just as i was about to leave i drove about 200meters to the tap to fill 2 bottles up with water, popped the bonnet again to check and the rad cap was off and lucky got caught in the engine bay but the rubber seal was missing. looked everywhere for it but couldn't find it. i put the cap back on but it was so loose it would of came off straight away. 500miles away from home and no breakdown cover aboard, things wernt looking up. After talking to the show organisers one helped me out and put some kitchen roll round the cap and putting shit loads of duct tape to hold it down. I managed to get all the way home trouble free so head gasket must be fine and i must of just blown the seal to the rad cap so a quick easy cheap fix luckily. Another bit of bad news is as it was so frigging hot, as i started to clean my car there just under the headlight on the front bumper it started to sink, by the awards it cracked. But that will get sorted soon when lee is back from holiday at L.A.Paintworks. filler was fine all English summer but that heat was to extreme!
