200 gettin' down
  • #76
    ha piggyback
    IG: awscarguy
    '90 Jetta - TSI swapping
    '13.5 Jetta GLI - new daily toy
    Haus of Dub
    • #77
      3bar map is here....that was the last item for the ecu.
      IG: awscarguy
      Haus of Dub
      • #78
        made the attempt to start it this weekend. no spark. need to double check my coil grounds back the to standalone
        so i did some forza in the meantime...
        IG: awscarguy
        Haus of Dub
        • #79
          wideband is here and took the liberty to enabled the onboard accelerometers
          IG: awscarguy
          Haus of Dub
          • #80
            getting back on track...
            I have been battling coilpack spark issue for a while now. I am using the vw 2.5 coilpacks and they work in place of 1.8t coils....but i cant get spark. so i swapped in a 1.8t coil.....
            i have tried different dwell times and cant get them to fire. the 1.8t coilpack is just too short to fit my stock valve cover
            IG: awscarguy
            Haus of Dub
            • #81
              got my wiring sorted out. had to add a 1k 12v pull up resistor.
              on to finishing the car!
              good day
              IG: awscarguy
              Haus of Dub
              • #82
                I want to hear this monster!
                R.I.P P.WALKER 2013/11/30
                • #83
                  will be on the ground today yay!
                  IG: awscarguy
                  Haus of Dub
                  • #84
                    Nice man! these things have oem external wastegates?
                    • #85
                      yup 35mm
                      IG: awscarguy
                      Haus of Dub
                      • #86
                        snaps and pops......almost like its out of phase....
                        IG: awscarguy
                        Haus of Dub
                        • #87
                          my crank trigger need adjusted, hence why no fire
                          now i can put it on the ground....
                          IG: awscarguy
                          Haus of Dub
                          • #88
                            This pleases me, finish it!!
