I'm the dude, man.
  • #91
    and the solid subframe bushings
    one done:
    and all the rest, along with the diff solid bushings:
    and new favorite tool just because
    Dude... My nissan has like a v8, man.
    • #92
      nice gloves, dudette.
      • #93
        and the final update for now, the S15 HLSD upgrade.
        OE open diff:
        poof gone (yeah I cleaned that out too, just forgot to take a pic)
        ring gear off of old diff and new hlsd, forgot to take pics of me taking it off )that shit isn't normally easy....unless you have a nice impact )
        Now I have put it all back together, but forgot to take pics after I smashed/cut my finger when dropping the new diff in. You see I had to hold the bearing guides on while lining up the diff, while trying not to actually "drop it" and it caught my thumb going in, lots of fun.
        Anyways I temporally put the cover on and degreased\washed\sanded the outside,
        taped it off, and painted (no POR15 has it has a protective coating already and there wasn't any rust):
        pressed in the final Diff bushings, touched up the paint, installed the gasket, and torqued to spec.
        all it needs is some fluid and its good to go
        more updates soon
        • #94
          don't be jealous
          • #95
            You know with diffs your suppose to set pinon depth and bearing pre-load right?
            The Kia has been parted.
            • #96
              Oh I know you're supposed to, and normally I'm all for doing things correctly.
              However from the research I've done it isn't needed for the HLSD.
              • #97
                I'm not saying your lying, but that's just weird to me.
                • #98
                  lol I know.
                  From what I understand its like I just took my open diff out and put it right back in.
                  As long as you follow the order and put everything back in exactly as it was taken out, it works.
                  I must have read about 20+ posts of people saying thats all they did and they are at 20k + miles.
                  I'm guessing the OEM spec has rather high tolerances.
                  • #99
                    Ahhh that Kouki is so sexy.
                    Beautiful car, I can't wait to see what happens to it. Suscribed!
                    • wow talk about a build thread! fuckin awesome dude, can't wait to see the finished product..
                      • Good stuff, subscribed.
                        56' Big Back Glass Chevy
                        08' Audi S5
                        • some more updates
                          went ahead and got an agitator for my bolts and what not
                          brake cylinders before cleaning
                          pressed them in and assembled the calipers
                          • Some more brake goodness
                            and back together
                            brake pad assembly
                            and all on
                            got the rotors resurfaced and put it all on with SS lines
                            • and the rear calipers
                              pistons
                              and together
                              forgot to take pics of them on and with brake pads
                              Ebrake setup, painted flat black shields
                              had to put the copper spring holder through the upright and shield, was a huge pain in the ass
                              so many parts
                              new springs and stuff
                              how they go on
                              brake grease in the right spots according to FSM
                              almost done...
                              with the adjuster
                              all done and bolted up to hubs
                              • adding fluid to the diff, only the best
                                rear end all together looking pretty
                                another
                                close up
                                and on
