Final specs are 16x9.5 on all four corners, 26mm spacers in the front 38mm offset wheels, 35mm spacers rear 38 offset wheels.
E30 "Mad tyte jdm" 1JZ-GTE build
Well over the last few days Mike and myself have been working on his exhaust. It is a fully 3" equivalent ovalized tube exhaust, v-band clamps, etc.
We just tacked it together, and Mike is dropping it off tomorrow to have it tigged.
Time for some pics!
And some badass pie-cut work.
Originally posted by KielanWell dip me in shit and roll me in breadcrumbs...
got my exhaust back all nicely tigged..
clearance is much more gooder
just have to make the axle back section now
Looking awesome so far!
If you don't mind posting the dimensions on that steel tube you used to make the lower rad support I would appreciate it. I want to do something very similar seeing as my skid plate currently mounts to the paper thin oem rad support and is doing a good job crushing it.
I'm not 100% sure off of the top of my head, but I think it was 1 3/4" x 3" with 3/16" wall thickness. I just went to the local steel supply and had a look at their cut peices, and grabbed what would work. hope this helps.Originally posted by chrisbmx68 View PostLooking awesome so far!
If you don't mind posting the dimensions on that steel tube you used to make the lower rad support I would appreciate it. I want to do something very similar seeing as my skid plate currently mounts to the paper thin oem rad support and is doing a good job crushing it.Last edited by EuroNut; 11-11-2015, 09:35 AM.
Aw man, I know that fucking feeling. Best of luck with the rebuild man!
E30 V8 Build thread
Go here be happy!
Instagram: stuartrussell
yep that's what I did..good luck!Originally posted by chrisbmx68 View Postthanks for the info I thought it looked about like a 2x3 and the smaller pieces I assume you plug welded after inserting them into the upright portions?
Really sucks about the rebuild good luck getting it going again it will be awesome!
