Hammer-Time:. Can't Stance This
You should join Ratsun.net ...... . . . there are tons of KA24 Datsuns on there .... . . one 1980 210 sedan with a KA24DEOriginally posted by 1988montecarloss View Posthow big of a job was it to get the ka24de in it? i found a 1980 datsun wagon for sale locally and have been thinking about picking it up
depending on what kind of 1980 Datsun wagon........ you will most likely need to cut/flip the front crossmember, or build a custom rear sump oil pan
... you will need custom motor mounts, custom transmission crossmemberand mount ..... . shortened driveshaft
KA510 radiator might work,, , custom fuel pump set-up,,, either modify the tank and weld a in-tank fuel pump,,, or run a in-line fuel pump and 2 5/16" fuel lines
.. .. . tons of more work and custom parts required ....... . .. not to mention I spent 3 months on the wiring aloneLast edited by indy510; 01-26-2012, 10:17 PM.
