Okay... so... your offset should be the same if the face, lips, and barrels are all the same.
***My si dumped on bbs rs***
Either I'm missing something, or you are.Originally posted by fg2 sigh 07 View Postoffsets are +35 and +25 the lips are 1.5 on all of em lol. and im running a 5mm in the rear making it a +30.
They're all 9" right? And the lips are all 1.5" right? Which means the inside shells are all the same size.
And the face mounted in the same location relative to the center of the wheel assembly. And if the faces are identical, then the wheels will be the same offset.
If there's a 10mm difference, then either the face is different, or the rims are.
