Spider Weighs In
Been THRASHING the Spider over the past 3 days and testing all the gear. The suspension issue has been solved, corrected and now being fine-tuned to perfection. Springs on the coilovers are just on the verge of being too soft, but they are now working very well - compliant, smooth and supportive.
Just wrapped up tonight's beating and swung by my Bro's scales. With a full tank, she comes in at 2755 (1250 kg). With stock being 2500, the Spider is only 250 more than that with over 3 times the power. Now, a lot have requested the weight and I always make a point of informing them that the Spider was built with no real consideration to weight.
I added what I wanted and whatever it came to, that was that. In the future, I will shave it bit down here and there if I see the need for it. But for now, the only area that will see reduction is in the doors. More specifically, the window regulators and their wiring.
Went into the city earlier and what can I tell you about that? It was very eventful. We were even forced to stop in the middle of the road while some whipped out their iphones to take a few shots, then let us pass!!
Too funny!!
I can't even begin to describe the sound that comes on when I roll 2nd from 2500-6500...the cams, the ITB's, the exhaust...MAN!! Then do it all over again for third and forth?? Understand this, THIS is what I built her for. She looks just as mean as she sounds and performs. All the thumbs up and straight up respect I get on the road and at gas stations is beyond what I could ever of been prepared for.
This one guy even got out of his car when he caught up to me at a light, put both his arms up in the air and bowed!! He then said, "I would kill to hear that again. You built that? Guy, you matched the body with the perfect sound!!"
street
Too funny!!
street
The allen bolt that holds that port closed needed about 10 turns to close. Now I know why I have seen some smoke prior in the headlamps. Well, it's now tightened and cleaned up.
