Omg this just keep looking better! glad you changed the bumper design didnt really like the mesh effect.
Alfa Romeo Spider 3.7L 24V V6 Build
This topic is closed.
Street, this just keeps getting better and better with every detail you fabricate. the front end is really shaping up quite well, and I can really appreciate the amount of time and dedication that you are putting into these latest bits. This thing is going to be absolutely epic when complete, and so far things really seem to be paying off.sigpic
1982 euro porsche 930 turbo
Replys.
Originally posted by Jersh View Postgreat work man, definitely one of the most epic builds i've seen. the attention to detail is amazing.
street
Originally posted by jakkerd View PostNew bumper design looks much better.
Love this build.
street
Originally posted by Joshbm View PostOmg this just keep looking better! glad you changed the bumper design didnt really like the mesh effect.
street
Originally posted by 1badg35 View PostStreet, this just keeps getting better and better with every detail you fabricate. the front end is really shaping up quite well, and I can really appreciate the amount of time and dedication that you are putting into these latest bits. This thing is going to be absolutely epic when complete, and so far things really seem to be paying off.
street
Originally posted by mattc View PostAmazing.
Got to be my fav car build at the mo and one of the finest, inspirational car builds ever
Keep up the amazing work
street
Originally posted by MikeG View Postglad to see you put a proper alfa grille on...looks good
streetform - function - stance
Front Intake Tweaks Cont.
Work continues on the front end treatment into the next stage - refinement.
First off was the stiffer templates introduced for further mocking. Presenting: The fangs!
Watch them appear!
After I was satisfied with the general shape, I removed them along with the center panel and traced them to help realignment.
The latest evolution of the fangs.
Then I began tracing out the two central sections in favor of a single unit.
Then I jumped into another version of the heart's slates - on the bumper instead of the rad tunnel.
When the spacing looked proportionate, I cut them down and secured then with just enough tension to nudge them into corrections.
Then I put everything back together including the now one piece central unit and took a shot without the emblem to see how it looked. Fangs were left longer for adjustment room.
Fang's edges then cut down and seen from the side for spec check.
Then with the emblem. Not everything is in line. More tweaking is needed. I'' most likely redo the fangs as the outside edge does not have enough roll to match the bumper and central unit.
As always the car is looking great. I was really looking forward to how the front end would come together and I am really liking the direction you re going.
If you don't mind me asking, what plans do you have for the finish on the fangs?
Replys.
Originally posted by Southwade View PostThat's starting to look downright sinister.
street
Originally posted by PMcD View PostAs always the car is looking great. I was really looking forward to how the front end would come together and I am really liking the direction you re going.
street
Originally posted by Riskant View Post+1
And loving it!
street
Originally posted by Sticky4 View PostNot sure how I missed this build until now, but holy crap.
Looks unbelievable, way to be original.
Can't wait to see more updates.
Spider Update.
Continuing with the refinement on the front end. Today I cut out a port for sump cooling at the bottom of the main panel. I also sourced the mesh I was looking for. This mesh is perfect as it'll allow for all the cooling I'll need as well as wiping out the distracting lines of the rad and fan.
Keep in mind, these panels are mere mocks. The real-deal ones will get CNC'd or lasered.
Love seeing updates on this.
I'm really glad you take your time (although you move a damn good pace), and consider functionality along with the aesthetics. That is the true testament of BUILDING a car.
I really hope to see this car in person so I can really appreciate it. Sad to think that there is a good chance that I may not.
Keep up the good work street!
Reply.
Spider Update.
While studying the latest shots last night, I realized that a lot more subtle tweaks were needed.
In today's update, here's what was altered:
Enlarged the bar between the sump and rad port by a 0.25 inch.
Shortened the height of the main panel by 0.5 inch.
Enlarged the sump cooling port by 0.25 inch.
Moved the vertical curvature of the main panel inward by 1 inch.
Shortened the sump cooling port horizontally by 1 inch.
Relocated the main panel's lateral edges back by 1 inch.
Increased the curvature of the main panel by 0.75 inch.
Much better flow now.
